| Jeansy001 |
 Jeansy001 Nova Slayer
 Posted: 15:32 - 30 Aug 2009 Post subject: Battery not recharging |
I just broke down and got picked up by the AA god bless them and he recharged my battery and i got the mile home i needed to but im still stuck as i have a battery thats not recharging. I had literally just rewired it gave it a new CDI Regulator starter solenoid and battery with a whole new loom!!
any ideas why its not recharging?? its a CBR 400 ____________________ CBR 400RR,cant get much more fun than that on the road |
| Wilson123 |
 Wilson123 Nearly there...
| Jeansy001 |
| Timmeh |
 Timmeh World Chat Champion
 Posted: 19:57 - 30 Aug 2009 Post subject: |
Another Honda 400 with charging issues. Seems to be coming a regular occurance.
Before you rip everything to bits, you can do some standard checks that just require the use of a multimeter.
1. measure the voltage across the battery with it off - it should be about 12.5-13v.
2. With the bike at idle (choke off), it should be about 13.5v
3. 3000-7000rpm it should go up to about 14.5-15v.
If you don't get these values...
Grab a haynes as they have all the values you need to find.
Check the resistance of the stator coil by sticking your multimeter pins in the connector block of the reg/rec. Check that they are within the range stated by haynes. You should also turn the engine over once or twice and check the value changes as the stator moves.
Next, test the reg/rec across its diodes using the little table and that you haven't got continuity where you shouldn't have using the bleep test.
If all that's ok, then in theory the charging circuit is working, now you just need to check you've got continuity from the battery to the reg/rec's output.
HTH  ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Jeansy001 |
| EUMP |
 EUMP Spanner Monkey
The last post was made 17 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
