KLX650 Cam Cap failure!
KevTM
PostPosted: 18:40 - 01 Sep 2009    Post subject: KLX650 Cam Cap failure! Reply with quote
I have a 1993 KLX650C1 which was running great and had been sitting for 2 days as I was waiting for new tyres etc.
I started her up only to hear a "crack" so shut her down. Took the tank, panels off etc so that I could start her up briefly to pinpoint the area of the now "tapping" noise. Sounded like it was coming from the cams so I took the cam cover off to check timing (which looks ok) but I did notice the leg that picks up the oil from the head on the cam cap had sheered off!
pic:
https://img.photobucket.com/albums/v407/Project_Sapphire/klx650_kev6_camcap.jpg
Is this a common failure? Anyone know any reason as to why it would do this? The galleries don't appear to be blocked.
Do you think having it welded back on would be do-able if I can't find a replacement?
finpos
PostPosted: 19:01 - 01 Sep 2009    Post subject: Reply with quote
That's very odd indeed, seen as that bit shouldn't be moving, so shouldn't be tapping! were the bolts loose at all? My guess would be it's a secondary failure after something much more hideous like a dropped valve.
You may have trouble with a replacement, that part will have been machined in place on the head to fit the cams, so you can't easily mix and match. (Look at the side of the cylinder head, it'll have two half moon cut-outs where the milling tool went in)
f.
KevTM
PostPosted: 19:06 - 01 Sep 2009    Post subject: Reply with quote
the leg that's broken off just rests on a o-ring. As you say though it shouldn't move! the tapping noise is only evident now as there's no oil feeding the cams? either that or it was the leg moving around
I don't see how it's possible for anything to even move/jump/etc to break that off.
All the bolts were still very tight, got the usual "crack" undoing them.
The leg fits on nice to the rest of the cap so I don't think a weld would be too difficult and the only pressure on it should really be the oil pressure.
finpos
PostPosted: 19:11 - 01 Sep 2009    Post subject: Reply with quote
KeV6 wrote:
Not sure why it would be difficult to replace really? or are you saying that the caps are individually machined to each head?
Yes - in the factory that bit is fitted to a head then the cam passage is milled out through the two half-moon cut-outs.
I agree it shouldn't be carrying any load and so shouldn't break, so re-attaching it should not be too difficult. Which still leaves a mystery why it broke and where the tapping is coming from...
f.
KevTM
PostPosted: 19:16 - 01 Sep 2009    Post subject: Reply with quote
I'll see if I can get a machine shop to weld it back on tomorrow and try it out and see if the tapping still occurs.
finpos
PostPosted: 19:22 - 01 Sep 2009    Post subject: Reply with quote
Just a thought - it may have cracked a long time ago if somebody had it apart and didn't follow the correct bolt untighten/tighten sequence (assuming you did Smile )
f.
KevTM
PostPosted: 19:26 - 01 Sep 2009    Post subject: Reply with quote
Yeah I checked the sequence from the manual before I took it off, and then noticed the sequence is stamped on the cap as well Thumbs Up
The last guy that had the bike didn't have much of a clue to be honest. I posted about my battery not charging in here before. Turned out he had it wired all wrong!
KevTM
PostPosted: 21:13 - 01 Sep 2009    Post subject: Reply with quote
On closer inspection I may have found out why it failed. It seems like someone has used a screwdriver to prise the cam cap up at the base of the "leg" where it seals against the head.. you can see the little notches on both the head surface and the surface of the broken off "leg" Confused possibly caused a hairline fracture?
Don't know why they tried that though as it's fairly easy to pull off without having to prise it to that extent.
PostPosted: 21:18 - 01 Sep 2009    Post subject: Reply with quote
They probably forgot to undo one of the nuts.
KevTM
PostPosted: 21:22 - 01 Sep 2009    Post subject: Reply with quote
probably Crying or Very sad which probably means they never bothered with the tightening sequence either Laughing
I'd rather have Stevie Wonder working on it than the people before.
finpos
PostPosted: 23:10 - 01 Sep 2009    Post subject: Reply with quote
They can sometimes be a bit of a mare to get off because there's usually two or more dowels around some of the cap bolts. Having said that, you can usually rely on the valve springs to pop the caps off quite smartly. Check the manual for dowels and check they are still in place if there are supposed to be any!
f.
KevTM
PostPosted: 22:49 - 02 Sep 2009    Post subject: Reply with quote
Nah dowels are there but it's still easy to pull it off without tools, done it several times now.
Got it welded ok, started it up and the ticking was still there. Took the head off and there was a small piece of copper or something?! It's a deep plug "cylinder" and I reckon it must have been below the hex on the old plug so when I took it out the bit fell in without me seeing it (changed the plug the other day) - Anyway, minimal damage done, little mark on top of piston and a little on the head but wont cause any probs.
Put it back together but having difficulty getting the slack out the upper cam chain, bit of a nightmare. Chain guides are correctly in place so no idea what it is.. will try again in the morning.
KevTM
PostPosted: 14:03 - 03 Sep 2009    Post subject: Reply with quote
All back together and sounding fine, exactly as it was before. Only had it ticking over with a few mild revs thrown in until the fan kicked in - all ok. Will take it a run later, fingers crossed!
The last post was made 16 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 2.77 - MySQL Queries: 13 - Page Size: 77.61 Kb
