Homemade carb sync tool Q.
ItzFluffy
PostPosted: 14:56 - 03 Sep 2009    Post subject: Homemade carb sync tool Q. Reply with quote
Well my bike needs alittle tune up so I thought I should finally get this done, its a cbr600 and I want to clean and sync them myself. I've been looking on the world wide web and found this:
https://i37.photobucket.com/albums/e86/Robb235/HPIM0628.jpg
Would that actually work??!!
If so, couldn't I make it in a smaller portion? Like a third of the size?
PostPosted: 14:58 - 03 Sep 2009    Post subject: Reply with quote
You could make it a third of the height if you used a liquid that was 3 times as heavy by volume. Mercury was often used for vacuum gauges partly for this reason.
ItzFluffy
PostPosted: 15:01 - 03 Sep 2009    Post subject: Reply with quote
Cool thanks. So heavy oil would work I'm guessing.
PostPosted: 15:04 - 03 Sep 2009    Post subject: Re: Homemade carb sync tool Q. Reply with quote
Yes.
No & no.
It is a very accurate way of measuring the vacuum difference between two cylinders but if there is a fair imbalance, the water/oil will move quite a long way up the tubes (that's what makes it very accurate). Long tubes = oil not being sucked into your carbs.
You could make a simple, single tube manometer and balance them in pairs. Balance them so they are all the same as #1. (so balance 1&2, then 1&3 then 1&4). Throttle adjuster mechanisms vary so you'll need to see how your particular setup works.
PostPosted: 15:07 - 03 Sep 2009    Post subject: Reply with quote
Oil is lighter than water so would be even worse.
ItzFluffy
PostPosted: 15:17 - 03 Sep 2009    Post subject: Reply with quote
Okay now I'm getting it. Awesome! This will same me a couple of hundred bucks. Dealers near me wanted $300+ to clean and sync them.
PostPosted: 15:22 - 03 Sep 2009    Post subject: Reply with quote
This thread from a month or 2 ago might interest you:-
https://www.bikechatforums.com/viewtopic.php?t=176914
The last post was made 16 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.81 - MySQL Queries: 13 - Page Size: 54 Kb
