Do I have a rectifier/regulator problem?
Polo
PostPosted: 06:30 - 04 Sep 2009    Post subject: Do I have a rectifier/regulator problem? Reply with quote
Hi peeps.
Before I splash out on a replacement, I just want to confirm that it is the rectifier that is dying.
My battery is but 6 months old at most. It pulls in 14.1 volts when my lights are off but only a maximum of 11 when the lights are on.
Meaning a night ride ends up with me having to bump start the bike when I cut the engine. Not a problem really - it's what pillions were invented for.
Is the boney finger of suspicion well and truly on the rectifier?
Many thanks. Thumbs Up
My mum smells your fingers
PostPosted: 08:08 - 04 Sep 2009    Post subject: Reply with quote
What bike?
Polo
PostPosted: 08:11 - 04 Sep 2009    Post subject: Reply with quote
1997 CBR 900 (RRV)
PostPosted: 08:21 - 04 Sep 2009    Post subject: Reply with quote
Do you have access to an ammeter (a high load one, 30A+ NOT a multimeter). This can give you a much better idea of how much power is going into/out of the battery when connected in series with the main fuse.
To be honest, it sounds more like a battery problem. I'd check the battery terminals are tight and corrosion free and check for a bad connection at the reg/rec terminal block and the main fuse holder.
Also check the battery electrolyte level if it isn't a sealed one.
Any other accessories (heated grips/alarm etc.).
EDIT: Standard lights?
Polo
PostPosted: 08:39 - 04 Sep 2009    Post subject: Reply with quote
Standard lights indeed. No alarm, heated grips etc. Only change, electrically, if you can call it that, is a Stebel horn.
I only know of multimeters, of which I don't own. A sparkie friend came and checked it last night and said what volts were going across it.
I will check the batter terminals etc and the rectifier. The battery is a sealed one and quite new.
I commute on it a lot, without the lights on, and it is absolutely fine. It is only with the lights on that it suffers.
PostPosted: 09:16 - 04 Sep 2009    Post subject: Reply with quote
Check for continuity over all the stator coils.
I have had a few dead regulator / rectifiers , but in all but one case they just died completely (and the one that didn't would randomly decide to charge the battery or not).
Polo
PostPosted: 09:45 - 04 Sep 2009    Post subject: Reply with quote
By continuity do you mean a regular voltage - both lights on and off?
PostPosted: 09:55 - 04 Sep 2009    Post subject: Reply with quote
Sorry, no. With the engine off disconnect the regulator / rectifier unit. There are probably 3 wires from it to the stator (quite likely all the same colour). Check the resistance over each pair of wires and they should be the same (ie, with 3 wires A, B and C, check A to B, A to C and B to C).
SW Motech Shop UK
PostPosted: 11:18 - 04 Sep 2009    Post subject: Reply with quote
Faulty reg recs are very common on early blades. Check the bikes earths are still connected and clean and check for corrosion in the connector blocks.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
The last post was made 17 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 62.96 Kb
