NSR125cc
GoldenRobNSR
PostPosted: 10:30 - 05 Sep 2009    Post subject: NSR125cc Reply with quote
i have got a nsr125cc when i brought the bike i was told it was derestricted but it does 80-85 flat with no modifications that i can see. any one know whether it is restricted?
T0MMY
PostPosted: 10:37 - 05 Sep 2009    Post subject: Reply with quote
https://www.improvresourcecenter.com/mb/images/smilies/popcorn.gif
ZX6R + CBR600RR
Jayy
Mr. Ponzi
PostPosted: 11:38 - 05 Sep 2009    Post subject: Reply with quote
The trick is, get a hose pipe to the exhuast and fill it up for a good 5 minutes or so, this will flood the restriction out but it won't harm your bike.
Hope this helps.
Luke_Retrofly
Silly Lesbian
PostPosted: 11:41 - 05 Sep 2009    Post subject: Reply with quote
Go here > https://www.nsr125.com/derestrict.htm
Sigh*
GoldenRobNSR
PostPosted: 16:17 - 05 Sep 2009    Post subject: Reply with quote
Luke wrote:
cheers only problem is it says restriced it will do 75 but mine does 85 and gets to 60 quicker than it says so im still not sure if it is or not restricted. any ideas?
PostPosted: 16:26 - 05 Sep 2009    Post subject: Reply with quote
GoldenRobNSR wrote:
Are you thick? If it says it does 75mph restricted and yours is doing 85mph doesn't logic say it's de-restricted? Rolling Eyes
GoldenRobNSR
PostPosted: 17:39 - 05 Sep 2009    Post subject: Reply with quote
yes logic says it is derestricted but if so why will it not do more than 85? unless there is something wrong with it that is what i was trying to ask in the first place. and no im not thick
tykey
PostPosted: 19:03 - 05 Sep 2009    Post subject: Reply with quote
has it got go faster stripes?
PostPosted: 19:13 - 05 Sep 2009    Post subject: Reply with quote
Why will it go faster than 85, it's an 18bhp 125. It's not about to set any speed records.
How fast do you expect it to go?
It'll be slower than RS125s or Mitos purely because it has less power.
GoldenRobNSR
PostPosted: 10:06 - 06 Sep 2009    Post subject: Reply with quote
because every were i have looked it says derestricted it should do at least 100
BenR
PostPosted: 10:12 - 06 Sep 2009    Post subject: Reply with quote
Honda say 28bhp. Have seen dyno printouts for 24bhp. Thumbs Up
Mystery
PostPosted: 10:17 - 06 Sep 2009    Post subject: Reply with quote
its still restriced i would say some where i've got a standard exhaust and unrestriced in the sprockets but will touch 100 if i redline in every gear and will cruise at 75-80 without to much probs
Luke_Retrofly
Silly Lesbian
PostPosted: 10:27 - 06 Sep 2009    Post subject: Reply with quote
Have you checked the 2 restrictions?
You may have 1 or the other, or your speedo may be wrong.
Is it an import, they will only do 85max, I know mine did and I couldn't de-restrict it fully.
PostPosted: 10:32 - 06 Sep 2009    Post subject: Reply with quote
Imports from some markets have restrictions in the CDI and power valve control unit which limit them to mid 80s mph even when full power.
Alains should be able to let you know the serial numbers of the units you need.
Luke_Retrofly
Silly Lesbian
PostPosted: 10:34 - 06 Sep 2009    Post subject: Reply with quote
What is 'Alains'?
The Original Muzza
PostPosted: 11:00 - 06 Sep 2009    Post subject: Reply with quote
Yeah Kickstart, you and your half-arsed comments. Laughing How will a new person know you mean a user on here? Wink
GoldenRobNSR
PostPosted: 15:42 - 06 Sep 2009    Post subject: Reply with quote
@blindweezy well i havent been redlining it just changing at around 10-10.5k of revs
@luke
no i havent had time to look the exausht looks like it has been welded near the end onf the can so i would say that has been done i will check the fuel when i get some time.
@kickstart im not sure if it is a import it is a S reg 99, and says SuperSprint on the rear farings.
i will get some pictures when i get some time.
PostPosted: 16:04 - 06 Sep 2009    Post subject: Reply with quote
You will probably have to check up with Alains with your chassis number to determine what market it was built for.
GoldenRobNSR
PostPosted: 23:34 - 06 Sep 2009    Post subject: Reply with quote
ok then i will do that thanks.
The last post was made 17 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 101.47 Kb
