Hornet restriction
That_Hornet
PostPosted: 16:27 - 06 Sep 2009    Post subject: Hornet restriction Reply with quote
Would I need to re sync the carbs when putting the discs in? And what possition would the holes go?
Noxious89123
PostPosted: 21:01 - 06 Sep 2009    Post subject: Reply with quote
Fitting restrictors shouldn't make any difference to the balance of your carbs, although hecking they are still balanced whilst you've got access to them wouldn't be a bad idea!
What do you mean about the position of the holes? It's just a large metal disc with a smaller hole in the centre.
MattHirst
PostPosted: 21:12 - 06 Sep 2009    Post subject: Reply with quote
I believe some of the 'washers' have the holes offset. I've also seen some that have a large hole in the centre/offset slightly and a much smaller hole aswell. Not sure why, must be to improve the fueling or something like that.
That_Hornet
PostPosted: 21:17 - 06 Sep 2009    Post subject: Reply with quote
Yea all 4 are off set. I know they all have to be the right way, but not sure as to the holes up, down, to the left, or right.
Confused
Just had them sync'ed so should be ok then?..............
Noxious89123
PostPosted: 21:19 - 06 Sep 2009    Post subject: Reply with quote
Hmm, now you mention it...
I think mine had the small hole towards the front of the bike.
Don't know if it makes any difference though.
That_Hornet
PostPosted: 20:03 - 19 Sep 2009    Post subject: Reply with quote
Bump. Embarassed
Dose anyone know what way the blades go in and if i need to change fule mixture?
As i see it, it restricts the air flow so less air it will run with to much fule. (The washers are possitioned between the carb and the head, if this makes a diffrence?)
MattHirst
PostPosted: 21:06 - 19 Sep 2009    Post subject: Reply with quote
They will restrict the airflow and fuel flow. I wouldn't of thought it would need re-jetting/re-mapping.
The 'washers' are designed to make the bike produce 33hp on a standard bike. If you re-jet it it may end up producing more power (is that possible? I'm not sure lol).
Either way, it should run relatively fine without needing a re-jet or whatnot.
That_Hornet
PostPosted: 17:57 - 20 Sep 2009    Post subject: Reply with quote
Ok then.
Thanks
Noxious89123
PostPosted: 20:47 - 20 Sep 2009    Post subject: Reply with quote
It's CV carbs, so the throttle slide + needle jet watsit thingumy open and close depending on air pressure to move the diaphragm.
Or something like that.
So basically, it doesn't need to be rejetted, and it won't run rich / lean.
That_Hornet
PostPosted: 20:52 - 20 Sep 2009    Post subject: Reply with quote
Onto the 2nd bit.
the holes are off set. What way do they face? I would think if i were talking in relation to a compas, i would think they were facing north?
Any one object to my assesment?
The last post was made 17 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 66.41 Kb
