| the rides nsr |
 the rides nsr Derestricted Danger
 Posted: 20:58 - 08 Sep 2009 Post subject: My NS125R Wont Start Help Please |
alright everyone was wondering if you can help me,
I was just riding home from work in the rain and my ns125r started sounding really weak like it had no go until it got into the powerband, i then came to a junction and she just died . i then tried to kick it off but it wouldnt so i tried bumping it off it did start but just died when i stopped reving her. so i just kept the rev's on put her in first and rid home. she did sound little bit weak but was still pulling OK. when i got home i checked the spark plug and it looked fine and check the spark again looked good checked the compression that was also good. when i kick started it after i put the spark plug back in and connected it made like aloud poping noise???? when i bump the bike and it starts i have to give it rev and it slowly picks up the rev and then revs normaly but as soon as i put her in neutral and release the throttle she dies??? has water done oat to my bike as it was raining very hard but before all this the bike was running spot on that day from starting it upto leave work, it was only when i got close to my house that it stoped working properly ? any help please  ____________________ The roads of the world need to have rubber burnt on them !!  |
| dardappa2004 |
 dardappa2004 Nova Slayer
| the rides nsr |
 Posted: 22:23 - 08 Sep 2009 Post subject: |
how do i go about checking my ht lead ____________________ The roads of the world need to have rubber burnt on them !!  |
| the rides nsr |
 Posted: 22:59 - 08 Sep 2009 Post subject: |
ye it has the standard air box. when i was checking for the spark i did get a little electric shock from the lead and i was holding it with plyers on the rubber bit. ??? ____________________ The roads of the world need to have rubber burnt on them !!  |
| the rides nsr |
 Posted: 23:00 - 08 Sep 2009 Post subject: |
how do i test that my ht lead is ok ? and with a spark coming out of the spark plug when tested againest the fram wouldnt that suggest that the ht lead is ok ? thanks phil ____________________ The roads of the world need to have rubber burnt on them !!  |
| Wilson123 |
 Wilson123 Nearly there...
| the rides nsr |
 Posted: 23:20 - 08 Sep 2009 Post subject: |
it has got a new spark plug in and makes no difference. if there is a spark at the plug wouldnt that mean the ht lead is fine ? ____________________ The roads of the world need to have rubber burnt on them !!  |
| the rides nsr |
 Posted: 20:20 - 09 Sep 2009 Post subject: |
i have tried 4 different spark plugs and all dnt make it tick there is also sometimes when i kick it , it will make a loud sort poping noise ?? any ideas cheers phil ____________________ The roads of the world need to have rubber burnt on them !!  |
| taz4626 |
 taz4626 Renault 5 Driver
| the rides nsr |
 Posted: 21:22 - 09 Sep 2009 Post subject: |
i havent changed the ht lead YET. how ever prior to this problem am in now i had a problem with the bike shutter through revs of 5000rpm to 6500 rpm and this problem started from me running out of fuel , kieth suggested that there is a good possibility in that some crap from the bottom of the tank had gone into the carb and got stuck in the jet. Now i was wondering if it is possible that the jet has fully blocked and fuel cant get through , although when i bump the bike it will start after a really good push but i have to keep the revs on otherwise she will just die. when i am reving it though it does sound sort of weak????? thanks phil ____________________ The roads of the world need to have rubber burnt on them !!  |
| the rides nsr |
 Posted: 02:40 - 10 Sep 2009 Post subject: |
ok so i took the carb off and took the bowl off and it was clean as a whistle. look through the jet no blockage was refitted it and tried bumping it off she did start up however the same problem came once i had stopped revving the bike and it died so i am going to replace the ht lead and see what happens then. If i replace the ht lead and its still the same what eles could it be ? thanks phil ____________________ The roads of the world need to have rubber burnt on them !!  |
| the rides nsr |
 Posted: 11:25 - 10 Sep 2009 Post subject: |
just replaced the ht lead and no different. she seems to be ok and you can rev it but as soon as u let then rev drop more then 2000 she will die any ideas ??? thanks phil ____________________ The roads of the world need to have rubber burnt on them !!  |
| the rides nsr |
 Posted: 00:38 - 11 Sep 2009 Post subject: |
where is the idle jet ? also i have just looked at where the exhaust connects to the engine and there is like oil all around it ? i am guessing that aint good what could that be? cheers phil ____________________ The roads of the world need to have rubber burnt on them !!  |
The last post was made 17 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
