Busa Dyno Run
SRADkneedragg...
PostPosted: 03:12 - 09 Sep 2009    Post subject: Busa Dyno Run Reply with quote
Thread posts were removed due to Devans and chris-red rude remarks.
Sorry I won't tolerate the rude insinuations.
Marie
HBR
192MPH
Sponsored by Brock's, Tiger Racing, Nitrous Express, FamilyPowerSports, GenMar, and the Lightfoots HeavyBusRacing.com
cyclops12
PostPosted: 03:46 - 09 Sep 2009    Post subject: Reply with quote
Should of changed a couple of your stacks wilst doing the airbox mod , 4 long stacks for midrange or 4 short for top end power
and if you only use the busa for top speed runs you could of done the full [ eggbox ] airbox mod for a couple more ponies Thumbs Up
hayabusa trike
PostPosted: 10:24 - 09 Sep 2009    Post subject: Reply with quote
With the power and speed, entirely possible. You bike also has a very wide spread of peak power which will make gearing easier. Neutral conditions it should manage 185~186mph on standard gearing. So having slightly favourable conditions would see it through to 187mph.
Graph of real wheel thrust against drag for your 'busa from the dyno graph you put above. The black dotted line is the drag for a 'busa (based on a Cda of 3.36).
The last post was made 17 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 37.14 Kb
