Rev counter
Mr White
PostPosted: 09:01 - 12 Sep 2009    Post subject: Rev counter Reply with quote
Hi I own sachs xtc, my rev counter is dead.
Can I use any rev counter as a replacement?
Or where do i find cheap universal one?
cammy mack
PostPosted: 11:15 - 12 Sep 2009    Post subject: Reply with quote
are you sure its not the cable thats shot?
google or ebay usually works Thumbs Up
EDIT
https://cgi.ebay.co.uk/CUSTOM-CHROME-STREET-FIGHTER-TACHO-CLOCK-REV-COUNTER-_W0QQitemZ120460653481QQcmdZViewItemQQimsxZ20090820?IMSfp=TL090820159002r1498
HTH Thumbs Up
00Reid
PostPosted: 16:01 - 12 Sep 2009    Post subject: Reply with quote
I'd also like to know if i can fit a universal or replacement rev counter for a very old CG125.
It has had a replacement engine casing with a rev counter, so i have the bottom end but no dial.
PostPosted: 16:23 - 12 Sep 2009    Post subject: Reply with quote
Most older bikes use rev counters that are cable driven. On these you need one that is geared the same.
Newer ones tend to be electronically driven. Either from a signal from the ECU or just by a pickup on the coil. With these you just need one that provides the same signal, and from the coil that pretty much only means one with the same number of cylinders / coils (ie most 4s use 2 coils with a wasted spark system).
00Reid
PostPosted: 20:50 - 16 Sep 2009    Post subject: Reply with quote
Mine is cable driven.
Any ideas where I can get my hands on a rev counter with CG125 or similar gearing?
I have looked for CG125 specific dials (with counters) but with no luck, strangely.
Thanks,
Phil
PostPosted: 21:07 - 16 Sep 2009    Post subject: Reply with quote
Does the CG125 even have a mechanical drive for the speedo.
Alexio
PostPosted: 23:38 - 16 Sep 2009    Post subject: Reply with quote
Not 100% sure what you mean by the terminology there, but I think it does yes. I just changed the speedo cable on my CG today and it's a cable that goes from the front wheel right right to the clocks. There's a rotating cable inside that has a bit of square type metal at each end that turns when the front wheel turns?
Edit, oh right, you mean mechanically from the engine as this would be applicable to finding out if you could have a rev counter or not?
Then I guess no... I can't think of a quick way you could get a rev counter on a CG125.
PostPosted: 23:40 - 16 Sep 2009    Post subject: Reply with quote
Sorry, typo. Meant mechanical rev counter drive Embarassed .
The last post was made 16 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 57.99 Kb
