WHEELS-paint or polish?
stirlinggaz
PostPosted: 10:48 - 12 Sep 2009    Post subject: WHEELS-paint or polish? Reply with quote
hi all,
currently "restoring" a 1992 mito.
its gonna take me while to get it done, so times not really an issue.
neither is cost, as i got the bike cheap enough & it doesnt "need" much doing to it.
its just "cosmetically tired"
the coating on the wheels had started to peel off.
so i attacked them with a pressure washers to remove any loose paint. (see 1st pic)
now i dont know whether to
A :give them a few coats of hi-build primer & then paint/lacquer.
B : give them to a professional to be shot blasted & powdercoated.
c : get the old "paint" removed & attempt to polish the bare metal up.
the spokes on the rear wheel come apart & i have just given it a rub with steel wool & i think it could be polished up,what do you think? (see pic 2)
obviously option B would be the easiest, just hand them over, pay the money & the wheels come back like new.
but im not known for taking the easy option, lol
i quite fancy the idea of polishing them up, then maybe coat with clear lacquer.
having never done wheels before, im looking for opinions/experiences.
done plenty of other painting before, with aerosol & gun. (i have a compressor & hvlp gun) but not on wheels.
& i've done some polishing before. (removed anodised coatings & polished up to a nice shiney finish) im just not sure if it will be worth it.
cheers,
GAZ
SW Motech Shop UK
PostPosted: 10:52 - 12 Sep 2009    Post subject: Reply with quote
Unless you want to spend a large amount of your spare time rubbing autosol into the wheels dont get them plished. My Bandit 1200 has polished wheels and engine cases and it is a nightmare. Moisture in the air messes them let alone actually riding it near water. Stick to painted wheels mate. Always looks nice, easy to clean.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
PostPosted: 11:08 - 12 Sep 2009    Post subject: Reply with quote
Get the spokes and hub powder coated and then polish the rim. This way you won't have to remove the tyre and it gives you less polishing work.
PostPosted: 11:23 - 12 Sep 2009    Post subject: Reply with quote
Of course you will have to remove the tire, power coating is baked on at about 300 degrees Laughing
I would power coat it for the best results but you will have to remove the tire and bearings. You will have to get new bearings Which will be £20 according to wemoto. Plus getting the tire removed and refitted then it will be about £120 to get the wheels power coated. Don't forget to powercoat the sprocket carrier too.
It's not cheap but the finish will probably be better than standard.
PostPosted: 11:25 - 12 Sep 2009    Post subject: Reply with quote
Read what he said. You can remove the spokes, which means you can remove the hub. That's why I said polish the rim and powder coat the rest Rolling Eyes
PostPosted: 11:29 - 12 Sep 2009    Post subject: Reply with quote
It's a mito, it's a cast wheel Laughing
PostPosted: 11:30 - 12 Sep 2009    Post subject: Reply with quote
Holy shit the wheel comes apart Shocked
My bad
PostPosted: 11:54 - 12 Sep 2009    Post subject: Reply with quote
You only had to look at the second picture to see that Rolling Eyes
stirlinggaz
PostPosted: 14:37 - 12 Sep 2009    Post subject: Reply with quote
hi,
sorry, should have elaborated....
the wheels are cast,& dont actually come apart. (just the 3 spke "covers")
theres tyres on them, though they probably need replaced, so i could remove them & get them powdercoated but this seems too easy an option & also means around £120 to get the wheels done & even more for a set of tyres.
the 3 spokes have removable plates, why they come off i dont know., but you cant seperate the 3 spokes from the hub or rim.
i removed one of the spoke covers, purely to see what it looked like under the paint.
the paint comes off fairly easy & i think i could get the metal to polish up, which would take a fair bit of effort.
i realise that, if i did polish them, it would be a nightmare keeping them shiney, but would clearcoating them work?
cheers,
GAZ
mad4it028
PostPosted: 15:01 - 12 Sep 2009    Post subject: Reply with quote
i polished the whole wheels on my zx6r took ages to do and was a proper night mare to look after once it was done never again
https://img.photobucket.com/albums/v336/mad4it028/IMGP0870.jpg
https://img.photobucket.com/albums/v336/mad4it028/SDC11362.jpg
DONT DO IT NOOO DONT!!
stirlinggaz
PostPosted: 17:48 - 12 Sep 2009    Post subject: Reply with quote
hi,
what method did you use to remove the old paint?
those wheels look ok to me.
cheers,
GAZ
mad4it028
PostPosted: 19:06 - 12 Sep 2009    Post subject: Reply with quote
i used nitromorse they look ok yes but you wouldnt beleave the work it took to keep them that way not worth it in my opinion but hey live n learn Thumbs Up
The last post was made 17 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 76.35 Kb
