Leak?!?!?
That-Kid-O
PostPosted: 14:53 - 12 Sep 2009    Post subject: Leak?!?!? Reply with quote
This morning on the way to work I went to the garage to get the bike and after turning the key to ON position (not yet started up the engine) I was putting on my gloves and helmet only to realise petrol leaking from the gape between the petrol tank and fairing immediatly under it on the left side Sad
After powering her up and wiping it clean and setting off I kept checking on the way (had a 30 minute ride) it had stopped. Now im going to leave work around 5 and go check on her again and hopefully it will stop leaking.
Any ideas on what the prob is? The bike has a fuel injection system by the way...
EDIT by leaking I mean petrol started dripping out and went down the frame etc but only dripping not some sudden flush of petrol lol.
PostPosted: 14:55 - 12 Sep 2009    Post subject: Reply with quote
You have a fuel leak.
That's your problem. Thumbs Up
I would suspect a split pipe, or something.......
Whosthedaddy
PostPosted: 15:23 - 12 Sep 2009    Post subject: Reply with quote
Take it back to the garage and get them to sort it out.
yuri2085
PostPosted: 22:34 - 12 Sep 2009    Post subject: Reply with quote
Yer sounds like the garage did it, sounds like fuel pipe is leaking is an easy job- Although make them do it Smile Thumbs Up
MaybeGuy
PostPosted: 09:42 - 13 Sep 2009    Post subject: Reply with quote
or you over filled it and the fuel was coming from the overflow?
That-Kid-O
PostPosted: 17:48 - 13 Sep 2009    Post subject: Reply with quote
No the overflow pipes are lead down byt he kick stand and theres nothing coming from those ends the fuel leaks from in between the fairings down the frame.
I believe a pipe must be faulty but it has a warratny which should take care of it Wink
Thanks for the help though for all that wrote back.
That-Kid-O
PostPosted: 18:02 - 15 Sep 2009    Post subject: Reply with quote
Picked it up today. Apparently a "o-ring" on one of the injectors had a little chip which was letting the petrol through... He showed me the o ring they took out and it was indeed cracked so im now Very Happy
The last post was made 17 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 52.37 Kb
