Triumph reving to 3000 rpms
legsrgv
PostPosted: 00:34 - 13 Sep 2009    Post subject: Triumph reving to 3000 rpms Reply with quote
Hey guys new to all this, my triumph 900 runs great until engine warm then revs raise to 3000rpm only way i can drop revs is to slip clutch when in gear, at wits end worried about damaging clutch, poss mixture but hey what do Smile i no, thanks all for any help offered
LEGSRGV
PostPosted: 02:23 - 13 Sep 2009    Post subject: Reply with quote
Slipping the clutch should raise not lower the revs Confused
Alexio
PostPosted: 03:01 - 13 Sep 2009    Post subject: Reply with quote
I agree with chris-red and by mixture are you talking about your choke? Do check your choke yes and after that it would be on to looking at your carb. Otherwise that does sound like a bit of a mystery that makes entirely no sense.
MaybeGuy
PostPosted: 09:32 - 13 Sep 2009    Post subject: Reply with quote
or he means he's slipping it when its in gear at standstill so the revs drop.
turn your idle down when its warm so it idles normally.
PostPosted: 10:56 - 13 Sep 2009    Post subject: Reply with quote
Shouldn't you be writing a CV?
FerretFing
PostPosted: 17:05 - 13 Sep 2009    Post subject: Reply with quote
Check you have about 2mm of freeplay in the throttle & that the revs don`t increase if you turn the handlebars left or right - just warm the bike up for a few minutes then lower the idle on it (to around 1250 rpm) - do you need help locating the idle adjuster? Thumbs Up
PostPosted: 20:35 - 13 Sep 2009    Post subject: Re: Triumph reving to 3000 rpms Reply with quote
I had a similar problem on a couple of my bikes.
From what I remember, dropping the needle height was what was needed on the CCM.
I wonder if maybe your needles/tubes are a little worn, causing a similar affect.
Oh and it's Revolutions per minute - not revolutions per minutes. The Friday lunch time spin class woman at the gym always says 'RPMs', which leaves me feeling all itchy.
Alexio
PostPosted: 21:05 - 13 Sep 2009    Post subject: Re: Triumph reving to 3000 rpms Reply with quote
I think it's treating an RPM as a single unit, so RPM's as the plural represents many revolutions per minute anyway? Same difference.
SW Motech Shop UK
PostPosted: 08:05 - 14 Sep 2009    Post subject: Reply with quote
check it for air leaks.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
The last post was made 16 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 61.15 Kb
