fuse blowing
Richie529
PostPosted: 14:33 - 13 Sep 2009    Post subject: fuse blowing Reply with quote
hi i have an old gsxr 400 gk73a. When i let it run it gets to a certain temp then the fan kicks in and the main fuse blows. i have fitted a new thermostat and temp sensor. before i fitted these the fan didnt even kick in, it just blew. can anyone help me?
thanks Richie
steven_191
PostPosted: 16:02 - 13 Sep 2009    Post subject: Reply with quote
try a new fan.
if the windings inside are shot then you are getting a short circuit (positive from the battery goes to the fan, through a short circuit then directly to the negative). its the same as linking the positive and negative on your battery.
if you dont know anything about fan motors or how to test them just try a new one out.
seeing as you have replaced the temp switch and it now only blows the fuse when its needs the fan, id say that switch was knackered as well.
Timmeh
PostPosted: 18:33 - 13 Sep 2009    Post subject: Reply with quote
The switch is just a switch, the reason why its only happened now is because the switch was buggered and didn't turn the fan on.
Disconnect the fan and run the engine up to temperature, if it still pops the fuse its the wiring, otherwise it's the fan.
finpos
PostPosted: 21:38 - 13 Sep 2009    Post subject: Reply with quote
Good chance the fan is seized - a stalled electric motor is basically a dead short. See if you can spin the fan freely. What normally happens is the fan never runs for years until the cooling system efficiency drops, then the first time the fan ever has to kick in it's jammed solid.
f.
chris1984
PostPosted: 21:56 - 13 Sep 2009    Post subject: Reply with quote
what size fuse is it
Richie529
PostPosted: 17:16 - 14 Sep 2009    Post subject: Reply with quote
Its a 20A fuse
chris1984
PostPosted: 21:12 - 14 Sep 2009    Post subject: Reply with quote
Richie529 wrote:
Its a 20A fuse
Think thats your problem then mate as i think main fuse should be 30amp but i could be wrong.
The last post was made 17 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 50.32 Kb
