Rain: quick vs slow
Whosthedaddy
PostPosted: 17:58 - 15 Sep 2009    Post subject: Rain: quick vs slow Reply with quote
Like with the whole debate regarding do you walk or run to keep dry in a shower, could the same be said for riding in it?
What'd ya all think?
smegballs
PostPosted: 18:08 - 15 Sep 2009    Post subject: Reply with quote
We made an algorithm for this in maths once.......
I didn't really get it (not good at maths) but it boils down to you front section area versus the "top" section area.
If you have a much larger front section area (most likely) its better to go slower as you intercept less rain and your (relatively) small top section area will have less rain fall down on it even when you factor in the increased exposure time.
If by some strange factor your top section area was much much bigger than it would be better to go fast.
Obviously there are many many variables: how fast, raindrop density etc etc so theres no easy answer.....
HTH :roll
PS: Personally I find on a bike I get soaked in a few seconds, much more than I'd expect to do with the same journey (say across town) than I would on foot.
iooi
PostPosted: 18:11 - 15 Sep 2009    Post subject: Reply with quote
Given that you still travel the same distance and it rains the whole trip.
It makes no diffrence.
Are you any drier if you stand still or move when it rains.... Confused
The only thing you could argue on a bike is that greater speed is more likely to force the water up seams and any places where there is not a good seal. Due to increased wind pressure.
Bit like if you sit on your bike in the rain for 2 hours, but don't go anywhere, will you still be dry inside. Compared to riding for 2 hours at 50 mph.
PostPosted: 18:30 - 15 Sep 2009    Post subject: Reply with quote
Greater speed however also leaves you in more of a bubble of air going at a relatively different speed to the rain, meaning that especially with a fairing/screen, the rain is more likely to be forced over you by the airflow.
Depends a lot on the bike design, as some may as you suggest, force that water into rather than over you.
The View Askew
PostPosted: 18:37 - 15 Sep 2009    Post subject: Reply with quote
So essentially what we are saying is, when it's raining, you will get wet.
PostPosted: 18:40 - 15 Sep 2009    Post subject: Reply with quote
That's a good point, I should try and spam the Roadcrafter suit I'll have for sale - takes under a minute to put on and keeps you warm, safe and not wet Razz.
PostPosted: 19:01 - 15 Sep 2009    Post subject: Reply with quote
Given a fixed number of raindrops per unit volume of air, the speed is irrelevant, you still displace the same volume of air by moving through it from point A to point B and so encounter the same number of raindrops. Let's call this volume of rain Z in litres, representing the volume of rain hanging in the air displaced between the two points. This equals surface area (a) in square metres multiplied by distance travelled (s) in metres multiplied by the volume of rain (r) in litres per cubic metre.
Z = sar
Of course this is not the case because raindrops don't hang stationary in the air, they are falling onto you at the same time. If you had a speed of zero between points A and B you would get infinately wet. The longer you are in the rain, the more rain will hit you and will be directly proportional to time. So the volume of rain hitting you from above (Y) in litres equalls the rate of rainfall (R) in litres per second, multiplied by your top surface area in square metres (b), multiplied by the journey time (t) in seconds.
Y=tRb
So the total volume of rain which hits you over the journey (X) can be expressed:
X= Y+Z
X= sar + tRb
v=s/t (speed = displacement / time)
So, assuming a constant rate of vertical rainfall on an unfaired bike:
https://www.bikechatforums.com/files/eqn4551.png
Where X is the volume of rain you hit in litres where:
v is your speed (metres per second)
s is the distance travelled (metres)
t is the journey time (seconds)
a is the frontal surface area (square metres)
b is the top surface area (square metres)
r is the volume of rain in the air (litres per cubic metre)
R is the rate of rainfall (litres per metres square per second)
Therefore, you stay drier if you go faster.
Digitalize
PostPosted: 19:10 - 15 Sep 2009    Post subject: Reply with quote
If you fall off, you'll get very wet though, as you will be motionless, in pain, then trying to get back on the bike if its ok.
Ride to what you can in the rain, always stay confident, dont worry about getting wet.
Clanger
Stirrer
PostPosted: 19:11 - 15 Sep 2009    Post subject: Reply with quote
It depends largely on what sort of rain it is.
metalangel
PostPosted: 19:16 - 15 Sep 2009    Post subject: Reply with quote
I find the really light rain (that forms a fine coating of droplets on your visor) more hazardous and unpleasant than proper, heavier rain... not least of all because it doesn't tend to bead off the visor as quickly (if it all).
PostPosted: 19:32 - 15 Sep 2009    Post subject: Reply with quote
Little bitty stinging rain, or big old fat rain, rain that flies in sideways, or even rain that seems to come straight up from underneath?
doggone
PostPosted: 19:40 - 15 Sep 2009    Post subject: Reply with quote
The Stinkwheel formula doesn't take account that if you travel at 30mph rather than 60mph you will be out in the rain getting wet for twice as long. Rolling Eyes
PostPosted: 19:44 - 15 Sep 2009    Post subject: Reply with quote
TBH If you have a fairing you'll be kept drier behind it at speed, because every drop that hits the fairing doesn't hit your body. Many times I've ridden for miles down the A2 staying fairly dry only to get a soggy crotch doing the last mile and a half to my house at 20-30mph.
PostPosted: 20:12 - 15 Sep 2009    Post subject: Reply with quote
Yes it does.
Vertical rainfall (Z) = Displacement over speed multiplied by rate of rainfall times top surface area.
Do try to keep up.
PostPosted: 22:38 - 15 Sep 2009    Post subject: Reply with quote
HTH :roll
...so in short..Keep yer head down and pin it.......unless yer a pinhead
mark83
PostPosted: 10:16 - 16 Sep 2009    Post subject: Reply with quote
I like clutching it in the rain and spnning my back wheel up. i.e. savour the rain!!
But I'm sure it'll come back to bite me in the arse one day...
Kawasaki ER6n -> Honda CBR600RR -> Honda VTR 1000 -> Moto Guzzi Norge 1200
Buy my Mercedes 350 Sport AMG Evo
yuri2085
PostPosted: 21:14 - 16 Sep 2009    Post subject: Reply with quote
Something that has been overlooked is your not REALLY getting wet is rain is just falling on your helmet. (and then past your shoulders?)
Although ones legs do!
L3G3ND_MTX
PostPosted: 23:14 - 16 Sep 2009    Post subject: Reply with quote
Well normally theres only 1 kind, wet rain.
PostPosted: 23:24 - 16 Sep 2009    Post subject: Reply with quote
In Britain we have many types . i.e Deaf Dumb and Blind rain. You can't hear it you can't feel it or see it but you get wet.. Confused
Pat
The Artist
PostPosted: 23:50 - 16 Sep 2009    Post subject: Reply with quote
No
There is normal rain
then there is that really wet rain and then there is that fine rain that isn't heavy at all but somehow you get soaked anyway.
PostPosted: 18:19 - 17 Sep 2009    Post subject: Reply with quote
Raining cats and dogs - they are bastards when they hit your visor!
Whosthedaddy
PostPosted: 19:22 - 17 Sep 2009    Post subject: Reply with quote
Especially when you ride through a poodle.
Clanger
Stirrer
PostPosted: 17:07 - 18 Sep 2009    Post subject: Reply with quote
Don't forget the rain that is so wispy and barely touches you at all, so it couldn't really be defined as wet rain at all! Cool
Dom
PostPosted: 17:49 - 18 Sep 2009    Post subject: Reply with quote
Ba-dum-tisch. Laughing
Photos and that
The last post was made 17 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 134.49 Kb
