Help , problem with britsh gas...
dransy
PostPosted: 19:27 - 15 Sep 2009    Post subject: Help , problem with britsh gas... Reply with quote
Hi all , right for about 7 -10 months we have been in credit with our gas and elecy , i took a meter reading today as where moving out next month.
Anyway our last bill is about 2 weeks old says we are in credit on our gas by 264 quid , *great*
Our elecy in credit by 171 quid *great *
I ring up and gave readings and they are now saying we owe 180quid gas and 30 quid for elecy!!
And that we should be paying 77 quid a month for gas!!
Now me and the missus both work full time so its not like anything is used during the day PLUS its fucking summer all we use gas on is hot water on a night and the hobs to cook!
How can the fuckers say we are in credit by so much then say we owe 200 +quid in total for both!
wankers!
Is there anything at all i can do here?
thanks
teech
PostPosted: 20:35 - 15 Sep 2009    Post subject: Reply with quote
Unfortunately it looks as if you have been stung by a long string of estimated readings. Now they have the real one it looks as though you have been underpaying for a fair few months in retrospect.
This happened to me, we had gone months with estimated bills, only to find out that the cost of our consuption was about 30% higher than we thought. I now submit an online reading every month or so and it's now bang on accurate.
They are still theiving, overcharging bastards, but I think this time you may have been stung by circumstance.
In everyday life good people do good things, bad people do bad things. It takes religion to make a good person do bad things.
dransy
PostPosted: 21:08 - 15 Sep 2009    Post subject: Reply with quote
So do i just have to pay up? .
And now should i do readings like once a month or something?
I cant believe they are saying we are using 77 pound of gas a month though no way is that possible /
WildGoose
White Van Man
PostPosted: 21:37 - 15 Sep 2009    Post subject: Reply with quote
Chances are you just have to pay up, read the meter and do some sums. Most of the info for working it out is on the back of the bill, but may require some conversions etc.
You need to check your tariff to find out if you are using that much gas a month, and its complicated to work out, because so many units are at a standard rate, and so many might be at a discounted rate, then there is service/standing charges and rentals and all sorts of other crap, its designed to be baffling so they can shaft you as efficiently as possible.
Most utility companies will bribe you to pay by direct debit by offering you a discount, they will estimate your usage and fix an amount per month to pay, they will get this wrong then 10 months down the line they will read the meter and hit you with a bill for the deficit.
Paying a bill based on estimated meter readings is the same.
Make sure you know how to read your meter, and also have a key to access the meter cupboard (its amazing how many people don't). When they send you a bill, check the meter and ring them back with the correct reading, they will then adjust and send you out a correct bill, then pay the correct bill.
The more you check the meter yourself, the more you will get a feel for what uses the most gas/electric etc and the more familiar you will become with the operation of the meter.
Just look at the frequency of threads that pop out about people getting a shafting by these companies because they trust the estimates or pay by direct debit.
Quarterly billing, paying for what you use is the only sensible way to do it if you want stability in your outgoing finances.
In my area the savings to be gained from switching suppliers might add up to maybe £50 a year at best, i.e. not worth a toss. Worth checking, but there is no way to get cheap gas/electric unless you are stealing it.
They are all a rip off, and they will all get you in the end.
Even so called modern biomass energy supplies are a complete rip off unless you have your own source of fuel and can process it to the required specifications. I.e. you are a tree surgeon.
WildGoose
White Van Man
PostPosted: 21:48 - 15 Sep 2009    Post subject: Reply with quote
Quarterly Monthly Average
Electric (25.7.07-27.10.07) £30.61
Gas (3.7.07-3.11.07) £23.47
Electric (28.10.07-21.1.08) £38.88
Gas (4.11.07-21.1.08) £38.37
Electric (22.1.08-28.4.08) £50.20
Gas (22.1.08.28.4.08) £45.20
Electric (29.4.09-21.7.08) £30.73
Gas (29.4.09-21.7.08) £20.14
Electric (22.7.08-17.11.08) £39.78
Gas (22.7.08-17.11.08) £31.59
Electric (18.11.08-21.1.09) £81.78
Gas (18.11.08-21.1.09) £74.16
Electric (22.1.09-28.5.09) £68.20
Gas (22.1.09-28.5.09) £50.92
Here is a selection of my overly anal records of gas/elec since mid 07, the first column is what the bill was the second gives a rough guide to a monthly average.
The bill periods are in-consistent because I never pay up when they ask for it at an inconvenient time, it waits until the end of the next convenient month.
So you see, a £70 quid a month bill is quite possible during the colder months. This is also a very small house.
s44678
Guest
PostPosted: 23:45 - 15 Sep 2009    Post subject: Reply with quote
How much were you paying before on DD for you two? Definitely sounds like you were underpaying.
Essentially, if you've used that energy, you have to pay for it. But you don't have to pay it all at once.
The figure they are quoting now (80 a month for gas) is your usage plus the debt spread over the shortest time they thing they can get away with. Probably 3-6 months. The when that's paid off, they'll leave your direct debit at the higher amount so they can earn interest on what you overpay them. So, just ring them and tell them to bollocks and you want to spread it over a year. That's only an extra 10 quid a month.
If it's any consolation, we were paying £86 a month for gas and elec. 2 people in a 2 bed terrace house only in evenings and weekends.
Phoenix
Twisted Firestarter
PostPosted: 02:54 - 16 Sep 2009    Post subject: Reply with quote
When you go on direct debit they estimate and average which means when you want to read the meter and close the account you often get stung, the same if you have a long string of estimated readings. I supply an actual reading every time a bill is issued if the guy hasn't been to do it, i'd rather pay it now than have to pay a crazy bill the following quarter.
Gas and electricity bills really can be crazy, about 5 years ago (when bills were even lower) I lived by myself in a flat using economy 7 storage heating and a gas cooker working full time so not at home that often and in 6 months I had to pay up for nearly £600 in bills, I think there was something wrong with the meter personally as my next flat had the same setup except elecitric cooker and was nothing like it, unfortunately Npower (don't ever use them) couldn't be arsed to liase with the metering authority and sort out an inspection, the flat got sold on by the owners and nothing ever happened except I got raped on bills. And economy 7 is the most unecomonical form of heating....
iooi
PostPosted: 05:57 - 16 Sep 2009    Post subject: Re: Help , problem with britsh gas... Reply with quote
How does your reading compare to the last bills you got ? That is your best guide to if they have been underestimating your usage.
As to you working all day. All your electric stuff is still on. Fridge freezer etc. Do you have stuff on standby ? Uses power....
Same with the gas. What type of boiler is it. One that heats a tank, as it could be turning itself on and off all day heating the water up. If its a combi boiler then it won't.
PostPosted: 11:05 - 16 Sep 2009    Post subject: Reply with quote
Utility companies have little to go off except the estimated readings. Sure they can try to get the real readings but not enough people bother to return customers own readings or be in when a reader comes round. Sure they could pay to have the meter moved outside, but even if acceptable to the customer that is a large expense that is totally wasted when the customer moves to another supplier a few weeks later.
It is pretty easy for consumption to creep up, and energy prices have gone through the roof over the last 5 years or so.
You will have to pay for what you have used. Only long term solution is to make sure you give a reading each time they bill you.
Direct debit is cheaper and if you keep the readings up to date then you shouldn't land up in hideous debt or credit.
If anyone finds their electric bills are hideously high then get hold of a current cost meter (immediate consumption meter that clips onto the meter tails) and check what is actually using power. My fathers place had high bills and it turned out to be due to some incorrectly wired storage heaters (they were on at peak prices rather than just overnight).
JayA
PostPosted: 22:52 - 20 Sep 2009    Post subject: Reply with quote
Sounds like a catch up bill after estimated reads.... however...
Check you are being billed by the correct type of meter:
4 dial - Imperial - usually has .00 decimal points
5 dial - Metric - usually has .000 decimal points
If you have a metric and they are billing on imperial this will make a huge difference to your bill . ..much lower
Make sure you take readings on the day you move out or they will estimate your final bill.
And dont contact the call center to arrange a payment plan if the bill is correct. They will only usually offer you up to 6 months. Call the Customer Relations department straight off saying you are unhappy with your catch up bill and you believe they should have done a direct debit review on your account at least once a year to prevent this happening. You will probably get a much longer period to pay this off and more than likely a wee goodwill payment for your troubles Thumbs Up
Kawasaki Z750:~Sold / Kawasaki ZX-6R 07:~Sold / Aprilia Tuono 1000 R 08: / Triumph Tiger 1050
2E
PostPosted: 21:05 - 21 Sep 2009    Post subject: Reply with quote
key/card meters are the way forward.. Thumbs Up
sure you 'pay' more as they deduct money off it like 1p every hour or something but you control how much moneys on the electric and gas and top it up when you need to.. Smile
I moved into my 1 bedroom flat in May, found a letter for the previous tenant from NPower, rung them up assuming they covered my electric and actually they were covering my gas but switched over my electric to them... which is a shame as EON customer service was extremely helpful when i had problems with money on the key (the previous tenant left the meter in debt by running it to the emergency £5 and never topping up) Evil or Very Mad
The gas meter originally was a quaterly one, the electric was a prepayment key meter, swapped the gas over to the card type... nice new meter fitted NICE! Thumbs Up then they simply charged the card which the amount of gas we had used since moving in.. (something like £30) i didnt feel like arguing it so they took £3 every week for 10 weeks off the card.. worked quite well. Very Happy
My mum has a 7 bed house and at one time was being charged £120 for electric and another £100 for Gas, she switched to pre-payment and has practically HALVED her bill... Well worth doing IMO as these energy suppliers will stab you.. Middle Finger Middle Finger
No final bills, no shit, just put money on the card/key when you want to, SORTED. Thumbs Up
Got to say though, its the same really with alot of 'necessary' things... insurance, ALL SORTS OF TAX!!!, bills, and even repair jobs (home repairs, car/bike repairs etc)...
To be fair, i think its ironic when people preach about money management as well... i had a woman phone me earlier from some random debt consolidation company who was blabbing on about how better to manage my money..
I just said plainly ''ere, love; why dont you call number 10 downing street and give them the lecture on money management.. if it wasnt for them i wouldn't be having money problems!!' Laughing
Bringing Classic Bikes Back Into Fashion
Rides: 1980 Honda CX500
Fortuna
PostPosted: 01:06 - 22 Sep 2009    Post subject: Reply with quote
When our bill was high it was actually the meter itself that was faulty.
PostPosted: 09:31 - 22 Sep 2009    Post subject: Reply with quote
Personally I would say they are a last resort.
The electric companies like them for poor payers as it is extremely difficult to disconnect someone these days. Card meters just mean those who don't pay disconnect themselves.
The rates are normally higher and you miss out on the direct debit discounts (with npower for taking both gas and electric and paying by direct debit that is a £100 per year rebate).
Further you can easily land up in debt or credit on a card meter. Depends what the meter is set to collect which might easily be a higher of lower unit rate than you should be paying.
If you want to keep an eye on what electricity you are using at any moment then get a Current Cost meter.
D O G
PostPosted: 13:53 - 22 Sep 2009    Post subject: Reply with quote
Used to work in customer services for Northern Electric and Gas several years ago now, and this situation is common.
You have been billed on estimated readings as other people have said.
TBF, it says so on the bill, you really should've checked that the reads were accurate and provided your own, which you can probably do over the net now.
You will have to pay, after all you have used it.
As for the £77per month, that will be worked out to cover the actual usage, and recoup your shortfall.
Best way to pay for gas and elec is quarterly in arrears, and provide your own readings if estimates are used. That way you know what you have been used, and don't pay any money out before you have to.
You have learned a life lesson.
2E
PostPosted: 15:38 - 22 Sep 2009    Post subject: Reply with quote
Just for you dransy... something you can wear with shame
https://rlv.zcache.com/shafted_by_the_man_sticker-p217113071198863147tdcj_210.jpg
iooi
PostPosted: 16:38 - 22 Sep 2009    Post subject: Reply with quote
sure you 'pay' more
So if she has not changed the amount she is using then, she could be saving even more by being on a std tariff.....
Or is it a case of now she has to top a card up, that she is turning lights off and the heating is turned down a bit..
Most of the companies now make it easy to send them a update to reading when they estimate, either over the phone or internet...
To often its a case of pople being to lazy to check what the actual reading is.
I always make sure we note the reading on the same day the guy reads it. That way if he gets it wrong you have a idea of the problem.
Like everything in life.... Unless you do it, there is a dammed good chance it will be wrong Laughing
PostPosted: 16:43 - 22 Sep 2009    Post subject: Reply with quote
Or possibly she was in credit when she went to a token meter, and it is set with a low unit rate to repay that credit. If so once that credit has been used she will be building up a debt.
You can easily get into debt or credit with a prepayment meter. After all when did the energy company last send someone round to change the unit rate on the meter?
iooi
PostPosted: 17:51 - 22 Sep 2009    Post subject: Reply with quote
Yes something many people will not know about.....
customers pay for their energy upfront in the same way as a pay-as-you-go mobile. That's why six million of us currently use them. But some prepayment customers are receiving a nasty surprise in the post - a bill for energy they thought they'd paid for in advance.
Samantha England has paid for her electricity by prepayment meter since 2000, but received a bill from E.on in June 2008 for £1,162. She was told that her meter hadn't been updated by engineers for price rises dating back to 2005 and that E.on wanted to bill her now for the difference.
You would have thought with smart card techonolgy that the comsumer would buy X units when topping up the card, so no need for trips to change meter's. They would be updated at point of sale and the meter simply uses up the units as it goes along.
PostPosted: 18:46 - 22 Sep 2009    Post subject: Reply with quote
Smart prepayment meters were in use by a couple of the electric boards prior to full competition opening up (MEB was one, forgotten who the other was). However as most suppliers billing systems couldn't support them or support the infrasture to allow customers to recharge cards, etc, they have died a death. Part of the problem is that the meters are run by one set of companies and the billing is done by another now, so those owning the meters are not going to spend more money installing a smart meter that is of no benefit to them, while the suppliers don't want to pay out to the meter owners to fit those meters when the customer could disappear to another supplier at a moments notice.
The last post was made 16 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 118.14 Kb
