How do you balance carbs?
twotakt
PostPosted: 22:22 - 15 Sep 2009    Post subject: How do you balance carbs? Reply with quote
Need to balance mine and wondered what methods/tools people use and how successful/difficult they found them?
Do you go for this cheapo method? Click
Cheap (relatively) tool? Gunson Carb Balancer
Expensive posh tool? Davida 4-way Vaccum Gauge
For me, it'll be rarely used but I want something accurate enough for road use Smile. It's something that I'd only want to have to buy once, not interested in false economy.
R.I.P. Tareree Shiimi, 1985-2008
temeluchus
PostPosted: 23:31 - 15 Sep 2009    Post subject: Reply with quote
use a piece of metal rod and set all of the slides or butterflys the same against the rod and reset the idle screw. Dead easy.
The Original Muzza
PostPosted: 23:35 - 15 Sep 2009    Post subject: Reply with quote
Above method can be done, but vacuum gauge is most efficient.
Davida 2 cylinder gauge costs half the price of the 4 cylinder, and you can easily balance 4 cylinders using it.
Just keep one gauge on your first cylinder, then balance the rest from that, one at a time. Thumbs Up
FerretFing
PostPosted: 09:30 - 16 Sep 2009    Post subject: Reply with quote
I use this one;
https://www.carbtune.com/
twotakt
PostPosted: 11:25 - 16 Sep 2009    Post subject: Reply with quote
Ended up buying the Davida 2 Gauge, saves me £50 over the 4 gauge.
Cheers lads Smile
Rufus
PostPosted: 11:51 - 16 Sep 2009    Post subject: Reply with quote
ngsavfc wrote:
I use this one;
was looking at this yesterday as i phoned round a few garages asking how much to balance the carbs on the pooperdream and they all just ummed and ahh'd so fuck em.
how does it compare to the davida gauges? considering they're bloody expensive when compared to pattern gauges or don't you know?
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
the grim reaper
PostPosted: 12:16 - 16 Sep 2009    Post subject: Reply with quote
Right in a way but you'll find that the vast majority of IL4s are set-up so you have to balance carbs 1 to 2, 3 to 4 and then 1 and 2 to 3 and 4. You can do it with a 2 gauge balancer but it's quicker and easier with a 4 way.
I bought a Morgan Carbtune, top piece of kit.
Grim
twotakt
PostPosted: 12:25 - 16 Sep 2009    Post subject: Reply with quote
Whilst I agree it's easier, its doesn't seem to be an awful lot harder with the 2 gauge. Most IL4's have 3 adjusters AFAIK? (could be wrong).
No.1, balances cyl 1&2, No.3 Balances cyl 3&4 and No.2 balances 1&2 against 3&4. Like this:
https://www.zxrworld.co.uk/zxr400/workshop/carbs/carb5.jpg
With the 2 gauge, put it on cyl 1&2 balance, then on cyl 3&4 balance and then on cyl 2&3 and balance them against each other?
Please correct me if I'm wrong because I'll have to msg the seller to get them to upgrade my purchase to a 4 gauge Smile.
the grim reaper
PostPosted: 12:30 - 16 Sep 2009    Post subject: Reply with quote
You are absolutely correct, but remember that the engine always needs to be up to temperature before balancing the carbs and I got fed up with burning my fingers on the block whilst trying to change hoses.
As I said, a dual gauge will allow you to do the job but a four way makes the job easier.
Grim
The Original Muzza
PostPosted: 17:59 - 16 Sep 2009    Post subject: Reply with quote
Balancing with a 2-way takes longer, but jackdim wanted to be thrifty without purchasing a sub-standard piece of equipment. He saved 50 quid and got an excellent quality tool, extra time and fiddling is the compromise of the tight pursestrings of people like jackdim and myself. Laughing
beast rider
PostPosted: 18:49 - 16 Sep 2009    Post subject: Reply with quote
You could have bought these for less then the ones you got and they do all four at the same time
FerretFing
PostPosted: 18:54 - 16 Sep 2009    Post subject: Reply with quote
Rufus wrote:
ngsavfc wrote:
I use this one;
All I can say is they did the job for me - I don`t have anything to compare them to but found it easy to use (which I need!). I looked at various reviews & it seemed a safe bet Thumbs Up
twotakt
PostPosted: 19:20 - 16 Sep 2009    Post subject: Reply with quote
Noes it! 2 Gauge is enough and I got a top quality bit of kit Smile.
yuri2085
PostPosted: 19:24 - 16 Sep 2009    Post subject: Reply with quote
I used some cheapo thing with two tubes with a ball in each one, tube had two ends (for two cylinders) and the other tube had a ball just affected by gravity, to balance the cylinders one just needed to align the balls.
For 16 quid it worked pretty well although I did wish I didn't have to keep swapping around.
p.s. not INCREDIBLY accurate either but I believe it got the job done.
PostPosted: 18:25 - 17 Sep 2009    Post subject: Reply with quote
I tried a set of them once and they were absolutely terrible. THe hose barbs are huge compared to the adjustable restrictors so the hoses are impossibly difficult to fit on the gauges or leak air around the restrictor fittings, which is worse than not having a set of gauges as you get false results.
The Davida ones have restrictors built into the hose fittings on the gauges. They are really very good.
beast rider
PostPosted: 18:02 - 18 Sep 2009    Post subject: Reply with quote
Wow they must have been bad for you to tell me twice Very Happy
Peirre oBollox
PostPosted: 09:29 - 19 Sep 2009    Post subject: Reply with quote
I got a set of those spare, nearly new condition.
I recently bought a Pilot screw adjusting tool to do the job, almost no need to remove the tank, saving you time
yanto
PostPosted: 14:16 - 19 Sep 2009    Post subject: Reply with quote
ngsavfc wrote:
I use this one;
i have tryed them all i find these the best
The last post was made 17 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 109.49 Kb
