| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| binge |
 binge Emo Kiddy
 Posted: 06:51 - 16 Sep 2009 Post subject: |
If its running an oil pump, Then you will need to revert to premix, because in reverse the pump will become a sucker.
Apart from that, And possibly some advancing/retarding of the ignition timing, I am un-aware of anything else.
Of course, Wait it out and Kickstart will be around to bless you with some spectacular information about a 2 stroke engine from 1952 which was run backwards from the factory for some unknown reason.
Ben
| P.addy |
 P.addy Red Rocket
| The Artist |
 The Artist Super Spammer
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 07:32 - 16 Sep 2009 Post subject: |
you need to retard the timing (essentially advance the timing when its running back wards) find tdc and find out where its pick up is in relation to that, then go the same distance post tdc,
wrap the cable from the pullstart the oppisite direction,
you'll probally have to reverse the 1 way lock on starter gear, ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| UnknownStuntm... |
 Posted: 09:36 - 16 Sep 2009 Post subject: |
The engine isn't a motorcycle engine unfortunately, it's a disc cutter. Like wot those big blokes cut kerbs up with. So it has to be pull started backwards. I think the timing issue is a fairly straightforward one, I'll try it later on and come back if I get any issues - cheers chaps.  |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| B10Hazard |
 B10Hazard World Chat Champion
| steven_191 |
 steven_191 Nearly there...
| ms51ves3 |
 ms51ves3 Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 00:01 - 17 Sep 2009 Post subject: |
Timing will need changing. Doubt a basic engine has any advance / retard so that makes it a bit easier. Starter depends on how it is set up. Con rod might be slightly offset on the piston, but suspect it will be useable (just might wear a bit quicker and be a touch down on power).
If it is enclosed with a fan to cool it then this might not draw air through properly when running backwards.
| Blau Zedong |
 Blau Zedong Banned
The last post was made 16 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
