PW50 Piston Rings
Quote Me Happy
PostPosted: 11:06 - 16 Sep 2009    Post subject: PW50 Piston Rings Reply with quote
Hello,
I've got a little PW50 that needs a piston and ring change. All pretty straightforward but the kit I've received has three rings - two normal rings and a very thin, flexible ring. I presume the very thin ring must sit behind one of the other rings but which one?
The parts diagram I looked at made no reference to the thin ring, although it was for a later bike but I believe the design is the same since the start of production.
Thanks chaps.
https://www.bikechatforums.com/files/picture56835sdfgh.jpg
stirlinggaz
PostPosted: 16:18 - 16 Sep 2009    Post subject: Reply with quote
hi,
the thinner, flexible ring is the expander ring.
this fits in the bottom groove, before the actual ring,
make sure you get the main rings round the right way (the top ring is the "keystone" ring, & if they are stamped with a letter, make sure the leter is facing up..
cheers,
GAZ
PostPosted: 17:45 - 16 Sep 2009    Post subject: Reply with quote
If you search Google you will find many debates on whether the expander ring is any use. A lot of people leave them out.
stirlinggaz
PostPosted: 19:08 - 17 Sep 2009    Post subject: Reply with quote
hi,
tbh, i have left them out umpteen times & its never caused any problems.
but if the kit comes with an expander ring, then i'l usally stick it in, just for the hell of it.
never really understood its purpose.
cheers,
GAZ
Quote Me Happy
PostPosted: 09:04 - 19 Sep 2009    Post subject: Reply with quote
Thanks for the help Thumbs Up
I have hit another problem though - I've measured both rings with vernier calipers and they are the same size. The ring goes into the bottom groove of the piston no problems, the other top groove seems too tight and the ring doesn't seem to seat correctly. Is it a case of just squeezing it in harder? I didn't want to try as I might damage it.
Cheers.
stirlinggaz
PostPosted: 14:21 - 20 Sep 2009    Post subject: Reply with quote
hi,
have you got them in the right grooves?
i know you say you have measured them, but some rings are groove specific, due to minute differences to the shape/profile.
are the letters facing the right way?
does the piston have locating pegs & are the rings sitting correctly at them.
some rings are hard to hold in, almost cutting your hands, there is a tool for doing this, but i've never had to use one.
you sure you got the correct rings?
did it come as a kit?
cheers,
GAZ
Damon
PostPosted: 10:46 - 22 Sep 2009    Post subject: Reply with quote
as above, there are normally locating pins that need to be positioned at the opening of the piston ring.
Quote Me Happy
PostPosted: 11:24 - 22 Sep 2009    Post subject: Reply with quote
There were locating pins but the rings didn't physically fit in the grooves. Got it sorted in the end thanks to Tatters with a half bodge using the old piston,an old ring and a new ring.
Seems to have sorted it for now - I'll wait for it to blow up then have it rebored with a piston to match.
PostPosted: 11:30 - 22 Sep 2009    Post subject: Reply with quote
Often one ring is slightly wedge shaped. Hence measure the heights and they are the same, but the heights in the inside edge are different.
tatters
Exxon Valdez
PostPosted: 13:25 - 22 Sep 2009    Post subject: Reply with quote
Shitty pattern piston kits for lawn mower engines both rings were the same, the cyclinder was slighty scored and well worn so just used a new top ring on the old piston should get a few hours more out of it till it blows. was quite supprised the piston slapping stopped with one new ring.
temeluchus
PostPosted: 15:17 - 22 Sep 2009    Post subject: Reply with quote
https://www.federalmogul.com/korihandbook/en/index.htm
The last post was made 17 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 68.34 Kb
