Is this oil pump working...? (NSR 125)
RichP
PostPosted: 13:05 - 16 Sep 2009    Post subject: Is this oil pump working...? (NSR 125) Reply with quote
Since the previous owner of this bike seized the engine and i am now repairing it i thought i should check if the oil pump is working.
I took the output from the oil pump, normally going into the carb and turned the engine over a bit and no oil came out, is this a reliable test?
If not whats the best way to check?
Cheers guys! Smile
The Artist
PostPosted: 15:19 - 16 Sep 2009    Post subject: Reply with quote
Oil isn't going to squirt out. Only a small amount comes out over time. Probably 1% of the amount of petrol being used.
Best test is take the oil pump off, keep it connected to oil tank and put a drill on the bit that pumps it, keep it going for a bit and oil should slowly come out.
alains
PostPosted: 15:54 - 16 Sep 2009    Post subject: Reply with quote
if you want to do a realistic test , do this :
fill your tank with 2L of petrol and add 2 spoons of mixing oil
unplug the oil pipe from the carb and let the pipe in a small bucket at same hight as it's connected
start engine and with 2L engine can turn 1/2 Hour and you will see if oil is out from the pipe .
this is the method i employ when the pump has been drained
for your info you will use (approx.) 1L oil for 60L petrol
RichP
PostPosted: 16:05 - 16 Sep 2009    Post subject: Reply with quote
Ah ok cheers guys!
When i get the engine back together i'll run it on premix till im sure its working!
The last post was made 16 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 38.73 Kb
