standard vs iridium plugs + carb question
Rufus
PostPosted: 21:07 - 16 Sep 2009    Post subject: standard vs iridium plugs + carb question Reply with quote
apart from paying over the twice the odds what are the benefits of using iridium plugs over bog standard ones? (both are ngk)
and what tools do i need to balance my carbs? should i buy a carb adjustment tool?
thanks guys, still a mechanical noob but i'm getting there!
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
PostPosted: 21:20 - 16 Sep 2009    Post subject: Reply with quote
twin carbs are "easier" to do with a carb tool, but can do 4 carbs with a 2 carb sync tool Smile
plugs... i dont think people really notice too much difference..
my standard plugs are £2.29 each, iridium £9.19...
i'd rather save the cash... but ive never noticed a diff on my GS
Rufus
PostPosted: 21:33 - 16 Sep 2009    Post subject: Reply with quote
standard plugs it is, cheers.
off to m and p's on friday to grab everything. please await the obligatory *i fucked my carbs* post afterwards.
btw, do you only get 1 plug in a box? retarded question i know Razz
PostPosted: 21:57 - 16 Sep 2009    Post subject: Reply with quote
buy sparkies individually usually..
temeluchus
PostPosted: 22:38 - 16 Sep 2009    Post subject: Reply with quote
Iridiums are dearer but last longer so the cost is the same in the end. OEMs use em now to increase the service intervals.
Yes only 1 per little box.
nowhere.elysium
The Pork Lord
PostPosted: 10:17 - 17 Sep 2009    Post subject: Reply with quote
Wilson123 wrote:
Iridium do prove to be better. My engine was flooding plugs every 80(ish)km for months, someone recommended using an Iridium one, it was a long shot and all I got from the know-it-all's was "It won't make a different", "Waste of a money". It proved effective and I've had the same one for 2000+km
That kind of suggests that you're running too rich, as opposed to your plugs being rubbish.
Mr Hammers
PostPosted: 10:25 - 17 Sep 2009    Post subject: Reply with quote
An iridium plug was better in the NSR than standard, but the Bandit didn't seem so keen on them and lost a little of its 'zippiness', I found.
A Guide To Powerbands
temeluchus
PostPosted: 10:54 - 17 Sep 2009    Post subject: Reply with quote
Yes Iridiums ARE superior to stock plugs and yes they cope better with overrich fouling but its a small improvement.
The main benefit is longevity over stock plugs.
the grim reaper
PostPosted: 12:06 - 17 Sep 2009    Post subject: Reply with quote
Bear in mind that cleaning iridium plugs is a no-no, they are soft iron coated with iridium, scratch through the iridium and the plug will eat itself.
They are more resilient to sooting up but only marginally.
Carb balancers come in all shapes and sizes and costs! I use a Morgan carb tune (4-way) but only because I don't like burning my fingers changing hoses over.
Remember, if doing an IL4, that you'll have to balance carb 1 to 2, then 3 to 4 and finally 1 and 2 to 3 and 4.
Grim
Rufus
PostPosted: 17:11 - 17 Sep 2009    Post subject: Reply with quote
Grim
the morgan carbtune was on my shopping list as apparently it's good Smile thanks for the heads up grim Thumbs Up
edit:
just thought i'd fit this in. the bike idles but after a while there are intermittent drops in the revs, like it's going to stall and then just go back to normal, any idea what causes this? (hoping that the carb clean and balance will sort it)
thanks guys.
The last post was made 16 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 75.52 Kb
