How do you?
How many fingers do you use?
All fingers used to cover the brake
12%
 12%  [ 8 ]
3 fingers used to cover the brake
15%
 15%  [ 10 ]
2 fingers used to cover the brake
38%
 38%  [ 25 ]
1 finger salute
1%
 1%  [ 1 ]
Don't cover it as a rule of thumb
32%
 32%  [ 21 ]
Total Votes : 65
Hex
Party Boy
PostPosted: 08:49 - 16 Jun 2004    Post subject: How do you? Reply with quote
...use your front brake?
Just a random morning thought.
When your riding and covering your front brake how do you do it? Do you use all your fingers, or just some?
I was always told off for covering my front brake as much as I did in my training, as when I did I always only covered it with 3 fingers and kept my thumb and pointing finger around the throttle.
To this day I still do, and still cover my front break a hell of a lot of the time.
So there you go just a bit of a random question really.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
tatters
Exxon Valdez
PostPosted: 09:14 - 16 Jun 2004    Post subject: Reply with quote
was told on CBT not to cover brake in case of a crash becuse l would loose my fingers Shocked , but expenance makes me cover it with two fingers beause it will increase brakeing reaction time in traffic
G1_
PostPosted: 10:10 - 16 Jun 2004    Post subject: Reply with quote
I don't cover my front brake unless I feel a particular need to. Like maybe filtering through heavy traffic.
dainesefreak
PostPosted: 10:19 - 16 Jun 2004    Post subject: Reply with quote
It varies for me, two fingers a fair bit of the time or if I feel I need to stop quickly four.
I was told not to cover my brakes when I was training too, I still do and always will do. If I feel that there is enough of a reason I cover to reduce stopping distance, I also cover the clutch ready to bang down the gears.
swaffs
PostPosted: 10:23 - 16 Jun 2004    Post subject: Reply with quote
I only cover the break when in traffic / filtering.
or of course stopping, by which time i'm already squeezing!!!!!
headlamp
PostPosted: 10:38 - 16 Jun 2004    Post subject: Reply with quote
Two fingers, all the time (I'm always filtering)
Using a mobile phone while driving a car should be made a capital offence!
Josh
PostPosted: 10:41 - 16 Jun 2004    Post subject: Reply with quote
I don't usually, but since I cut up a couple of my fingers and applied a makeshift plaster (normal ones come off inside my glove, plaster tape+lining=nice tight sticky home made plaster) I kind of have to cover it, or experience pain, and in all honesty, it is kinda useful, and after my test I may well do it more :>
04 Suzuki GSX-R 600 K4 - Sex on wheels :>
https://img58.imageshack.us/img58/6178/sig6dc.gif
Claud 14.7 to 1
PostPosted: 12:09 - 16 Jun 2004    Post subject: Reply with quote
Hmmmm interesting. For some reason i have never thought about covering the brake when filtering...i just scan left and right loads .may have to cover my brakes more though...
i suppose you could still keep the throttle open i bit (enough), and still have 4 fingers on the lever...Maybey not though. ill try
When i do cover its with closed throttle, 4 fingers on the lever...
Danny
Ask Me About Stoppie School
PostPosted: 12:18 - 16 Jun 2004    Post subject: Reply with quote
I usually cover the front brake with two fingers when filtering.
Stew
If it's good enough for top race teams...
PostPosted: 12:53 - 16 Jun 2004    Post subject: Reply with quote
I tend to use all four but that is due to my brakes being dire at the moment, if I used two and hard to really squeeze hard I could probably trap the other two fingers. Confused
Must sort them out really.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
Ninja
Caption Abuser
PostPosted: 13:00 - 16 Jun 2004    Post subject: Reply with quote
2 or 3 - all the time
James
4 wheels transport the Body ... 2 wheels transport the SOUL
priller
PostPosted: 13:03 - 16 Jun 2004    Post subject: Reply with quote
I always cover the brake with 2 fingers, the time spent moving your fingers could be the difference between hitting a car and missing it.
McJamweasel
BCF Junkie
PostPosted: 13:08 - 16 Jun 2004    Post subject: Reply with quote
When I'm filtering I always cover both brakes. Most of the time when I'm cruising on a motorway or fast dual carriageway I cover the front too. 2 fingers.
zaknafien
PostPosted: 14:02 - 16 Jun 2004    Post subject: Reply with quote
When i'm doing something that requires it as in filtering then I use 2 fingers.
Other than that I dont as if it's a panic type situation I wouldnt pull on those 2 fingers anyway i'd straighten them all out until they all covered the brake and then squeeze.
Just something i've always done in hairy moments.
02 Firestorm.
Hex
Party Boy
PostPosted: 14:13 - 16 Jun 2004    Post subject: Reply with quote
For those of you that cover your brake with 2 fingers, which fingers do you use?
If its not the little ones do you find you could trap them?
When I'm covering my brake with the 3 fingers even if I pull the brake right in my index finger wouldn't get trapped (I tried many times as this is a reason I was given not to do it).
When on the motorways I'm not always covering by the way, times when I'm filtering etc I am though.
McJamweasel
BCF Junkie
PostPosted: 14:15 - 16 Jun 2004    Post subject: Reply with quote
I use my first 2 - and I don't trap my other fingers cos the lever doesn't come back far enough.
karen_moomin
PostPosted: 14:20 - 16 Jun 2004    Post subject: Reply with quote
All fingers for me. I don't use my back brake so I must get out of the bad habit before it's too late.
Kris
PostPosted: 14:49 - 16 Jun 2004    Post subject: Reply with quote
2 fingers.
The brakes on the 9er are plenty strong enough. Plus my bike and I have only been together for a short while Mr. Green
www.prisonplanet.com
mrchips
PostPosted: 15:10 - 16 Jun 2004    Post subject: Reply with quote
I don't cover it except when riding in town or busy traffic.
Frost
PostPosted: 15:33 - 16 Jun 2004    Post subject: Reply with quote
I don't normally cover the front brake unless i have good reason too.
My foot is however, everready with the rear brake. Generally if in trouble i press ont he rear brake, then pull on the front brake.
JonB
Afraid of Mileage
PostPosted: 18:41 - 16 Jun 2004    Post subject: Reply with quote
I don't cover any of the brakes. I tend to use engine braking quite a lot, especcially out on the main roads where braking is not really needed. Smile
tgabber
PostPosted: 18:47 - 16 Jun 2004    Post subject: Reply with quote
Only cover the rear brake when filtering, find it much better for slow speed control. Also once dropped the bike when it was new and pulled up sharply with the front brake... Embarassed
"It's all about dislocating expectation"
Kawasaki KMX125 -> Aprilia RS125 -> Kawasaki ZZR600
EuropeanNC30R...
Gay Hairdresser
PostPosted: 19:10 - 16 Jun 2004    Post subject: Reply with quote
I only ever cover the front brake if I'm filtering or there's a chance I may have to stop suddenly. Use 2 fingers if I do, index and middle.
PostPosted: 19:31 - 16 Jun 2004    Post subject: Reply with quote
I cover the front brake with all 4 fingers most of the time, and from 2 many years on a 2 stroke I also cover the clutch much of the time.
iCraig
PostPosted: 20:34 - 16 Jun 2004    Post subject: Reply with quote
For some reason I never cover my brakes at all (unless I'm stopped at traffic lights I cover my rear brake and the same for when I'm filtering)
If I am filtering I more often than not cover my clutch, just my habit I spose, but then again I don't go at any great speeds when filtering, maybe 10-20MPH nothing faster though.
Infact saying that I very rarely use my brakes anyway, I use engine braking to slow down at lights and so on.
The last post was made 22 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.52 - MySQL Queries: 18 - Page Size: 133.49 Kb
