Sprocket Ratio Question
binge
Emo Kiddy
PostPosted: 21:47 - 17 Sep 2009    Post subject: Sprocket Ratio Question Reply with quote
Right, Probably one for Keith here.
My pit bike is running rather well, It has a bit more top end power in it, But wont get there because it splutters. Carb needs setting up.
It currently gets to about 66mph before it splutters. So running properly, I know it will get to 75mph easily.
Current gearing is:
428 Pitch Chain
16t Front
39t Rear
12" rear wheel with a 130/70-12 tyre.
I make the rolling circumference 1524mm
It pulls really well on this gearing, and will easily pull off taller gearing.
Sprockets I have are:
17t front
35t rear
How can I work out the top speed with just the 17t Front fitted, And then just the 35t rear fitted.
And then both 17t front and 35t rear fitted.
Ben
PostPosted: 21:48 - 17 Sep 2009    Post subject: Reply with quote
you could try matching your bike to a bike on the list and then customising your sprocket and chain set
https://www.gearingcommander.com/
PostPosted: 23:16 - 17 Sep 2009    Post subject: Reply with quote
Gearing commander will give you the basics. Current gearing will give you 81mph @10250rpm.
binge
Emo Kiddy
PostPosted: 23:38 - 17 Sep 2009    Post subject: Reply with quote
Cheers Keith.
Well if I run the taller gearing setting of the sprockets. 17t/35t. It will do 96mph. Laughing
Dropping the rear to a 33t would give me 101.8mph @ 10250rpm. Providing it will pull to said rpm.
Cool
The last post was made 16 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 40.33 Kb
