Shaft Drive, shafted?
Danny
Ask Me About Stoppie School
PostPosted: 11:45 - 18 Sep 2009    Post subject: Shaft Drive, shafted? Reply with quote
While changing the rear tyre on my BMW K75RT I noticed that the wheel doesn't spin freely.
i.e. trying to turn it as hard as I can results in about a 1/3 turn of the wheel.
When I removed the wheel and just tried spinning the brake disk I got a similar result and it feels very rough. It kind of feels really lumpy like a buggered bearing or something.
I suspect that the bike has been like this for some time and explains why it has been feeling especially gutless over the last year.
So any ideas on likely faults?
Thanks,
Danny
jay12329
Dr. Evil
PostPosted: 11:52 - 18 Sep 2009    Post subject: Reply with quote
On the hub behind the wheel there is a large caged bearing. This is covered by a rubber gasket, get a screwdriver and remove the gasket. And check the condition of the caged bearing. Mine lasted 58k before doing this...
https://www.bikechatforums.com/files/forfansoffail2.jpg
That was a really bad failure at about 80mph on a french m-way.
Cost me around 500quid to fix, but if its just started to go take your diff to BMW and it will be more like 200quid all in. Or do it yourself for 70 in parts.
More info here
https://www.ukgser.com/forums/showthread.php?t=159180
HTH
J
jay12329
Dr. Evil
PostPosted: 11:54 - 18 Sep 2009    Post subject: Reply with quote
Oh and BTW the wheel will never turn freely, the crown gear and shaft have a lot more weight in them than a normal chain set up. I could get just about a full turn if i gave it a good tug.
J
map
Mr Calendar
PostPosted: 11:59 - 18 Sep 2009    Post subject: Reply with quote
I believe it's good practice to always lube the splines on shaft drives whenever the wheel is removed using moly grease of the right carbon content.
Hope it turns out ok.
Suggest posting on one of the many BMW owner forums for their feedback / diagnosis.
Danny
Cheers Jay, I'll take the bevel drive off and have a gander. Thumbs Up
Ouch @ your pic btw! Shocked
jay12329
Dr. Evil
PostPosted: 12:45 - 18 Sep 2009    Post subject: Reply with quote
On these you dont access anything when you remove the wheel. You have to slip the bevel box off to access the shaft splines, but they should be happy and lubed until you take them off Smile
J
The last post was made 16 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 49.76 Kb
