NSR 125
aLcOcK
PostPosted: 14:37 - 18 Sep 2009    Post subject: NSR 125 Reply with quote
hi, I have just got a used engine off ebay as mine has broken. I just called up the garage for a few quotes.
he said for new piston and rings im looking at £50 to buy them then £50 for labour so £100 for piston and rings
then £18 for gasket
then £100 labour to remove and fit engine but he said im looking at £250 at the end of it for new piston and rings, gastet and for the engine to be removed and fitted.
Does this sound about right ?
is it easy to remove an engine from an nsr and re-fit it as this would knock off £100+
thanks Smile
Xanthic
PostPosted: 14:59 - 18 Sep 2009    Post subject: Reply with quote
Have you tried using David Silver Spares/Wemoto to see how much the parts are? Pay for the parts yourself then look to get the mechanic to fit them/rebuild... my mechanic was going to charge me £90 labour alone for a top end rebuild...
First & Current: Honda NSR 125 R1
Link fixed - https://apopandagumshield.wordpress.com
PostPosted: 15:04 - 18 Sep 2009    Post subject: Reply with quote
Removing the engine isn't difficult, but depends on how much experience you have.
Just watch out for the easily forgotten things that you suddenly find while trying to hold the engine in your hands. Like the oil pipe to the oil reserviour.
aLcOcK
PostPosted: 15:25 - 18 Sep 2009    Post subject: Reply with quote
i have looked on there and the parts are the same price as what he said
i have no experience at all and im doing this just by my self . . i have flicked thorugh the manual but there's quite a few pages . . does anyone have a guide on how to remove the engine and fit it again but once ive removed it i should know how to fit it again
PostPosted: 15:32 - 18 Sep 2009    Post subject: Reply with quote
Not sure of a guide. Generically.
Remove anything cosmetic (petrol tank, fairings, etc) and put it somewhere safe.
Unbolt the exhaust and take it off.
Unbolt the airbox, take it off and then take the carb off.
Disconnect the oil line to the oil tank. Make sure either you empty the tank first, have something to put the hose into for it to empty of you have something to block the line with.
Disconnect any electrical connections (temp sensor, ignition, neutral switch wiring).
Remove the chain.
Remove the gear change lever / linkage.
Drain the coolant (might help to remove the radiator as well, depends on the bike)
Slacken off the engine mounting bolts.
Support the engine, remove the mounting bolts and lower the engine. With a 125 engine a helper can probably support the engine for you. With a large engine you might want to play around with an engine hoist.
Reassembly is pretty much the reverse of that. But make sure you check the engine oil, bleed the 2 stroke oil system and double check everything is done up properly.
aLcOcK
PostPosted: 16:06 - 18 Sep 2009    Post subject: Reply with quote
Remove the chain.
thanks alot mate ill prob do that this sunday thanks mate
The last post was made 16 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.92 - MySQL Queries: 15 - Page Size: 52.25 Kb
