 cxjuggs L Plate Warrior
 Posted: 20:48 - 18 Sep 2009 Post subject: cg125 carb tuning |
I've just bought myself a '99 honda cg125 last week to practice on, ran okay but the carb needed cleaned out and while it was in bits, I figured what's the point of keeping the choke - you never need it (in non-cold london weather), so was wondering if I could just remove the butterfly plate?
For some reason, probably from the butterfly screws being overtightened and poor quality screw material - the threads on the screws got stripped/distorted whilst removing them. One of them went back in ok, but not the other... The one screw holds it ok, but I've not glued it yet, so not taking too much of a chance as it might well work itself loose.
Ideally I'd remove the whole spindle and block the hole off, but wonder if I'll then need to change the jet/needle to suit, or just adjust the mixture screw to make it a little richer ?
It's a HEIKIN PD88E carb - I'd assume that removing the choke plate will improve flow, throttle response and give faster acceleration - or are there better carbs to use on this engine?
Any thoughts appreciated, if this is a definate NO-NO as well, please let me know. Lastly I know it's only a cg125 so not expecting miracles or anything out of it, just want it to run the best it can for the few weeks/months I have it before buying a bigger bike.
cheers |
 Posted: 13:13 - 19 Sep 2009 Post subject: |
thanks bladrunner,
yeah, i know, going to just take the plate out, not worth the risk with only 1 screw holding it there, will probably oscillate, and the screw will fly loose into the fiery pit, causing much nastiness. think the plate would get stuck though, it's too big to fit through the inlet manifold end of the carb.
Would remove the spindle and block the hole but can't be bothered waiting for the aruldite to dry, want to ride today.
will try to find a replacement screw before it gets too cold and i need the choke, or i sell the bike.
yeah still using a standard airbox/filter - are there any documented mods to improve efficiency ? |
