water bottle pipe shearing. repair???
steven_191
PostPosted: 10:31 - 20 Sep 2009    Post subject: water bottle pipe shearing. repair??? Reply with quote
the pipe (i think its the overflow) has sheared a bit.
what can i do. plastic weld? or replace? or something else?
cheers
temeluchus
PostPosted: 13:46 - 20 Sep 2009    Post subject: Reply with quote
plastic metal will do the trick
Ichy
PostPosted: 15:35 - 20 Sep 2009    Post subject: Reply with quote
If it is the overflow then I wouldn't be too concerned. I'd look out for a cheap replacement but in the meantime you could plastic weld it yourself or use some expoxy adhesive to repair it. Alradite or JB weld.
steven_191
PostPosted: 16:38 - 20 Sep 2009    Post subject: Reply with quote
cheers. will probably do the araldite.
PostPosted: 20:47 - 20 Sep 2009    Post subject: Reply with quote
You should never get water out of that pipe anyway, it would take a serious over-heat or blown head gasket etc. I'd just leave the pipe off. Many water bottles don't have an overflow pipe.
trisers
PostPosted: 21:04 - 20 Sep 2009    Post subject: Reply with quote
Solder it!
Seriously, it's already been fused on in the factory by heat welding so get your soldering iron out, hold the split shut and gently start prodding it with the tip of a hot soldering iron. Tack it at intervals along the crack to hold it then start wiping the tip along the crack melting a little as you go. Take your time and do a small bit at a time allowing it to cool before doing another bit...i've repaired many small plastic bits like this, it's not structural so it'll be perfectly ok!
I'd suggest supporting the hose that attaches to it (cable tie?) so it doesn't get strained again too.
steven_191
PostPosted: 21:06 - 20 Sep 2009    Post subject: Reply with quote
trisers wrote:
Solder it!
good call. i just so happen to have a soldering iron right next to me.
Ichy
PostPosted: 21:44 - 20 Sep 2009    Post subject: Reply with quote
Damn it, I always thought they were blow molded.
Errrr, using a soldering iron on plastic is called 'PLASTIC WELDING'. You need a filler rod to do it right otherwise the plastic will be too thin and quite possibly ful of holes. Plastic straws work well.
steven_191
PostPosted: 20:26 - 22 Sep 2009    Post subject: Reply with quote
as i found out earlier. still its stuck now, i think ill chuck some araldite or something around it to put some strength back it as its a bit flimsy now.
cheers everyone
PostPosted: 23:40 - 22 Sep 2009    Post subject: Reply with quote
Just melt an old credit card into it. Thats how my dad repaired the bumper on my mums Mondeo.
Damon
PostPosted: 06:16 - 23 Sep 2009    Post subject: Reply with quote
cable ties work well too
The last post was made 16 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 68.8 Kb
