GSXR 1100 WP - Loss of power
EARTHWALKER
PostPosted: 23:34 - 19 Sep 2009    Post subject: GSXR 1100 WP - Loss of power Reply with quote
Hey all.
My ageing purple baby is a bit sick. All seems well until around 70mph and whammo!!! complete loss of spark until the engine slows and whammo again, full power, and the loop continues until I go a steady 60.
Always starts first time, and all lights, indicators, ignition lights work fine, so I'm not learning towards an electrical fault.
I've been told everything from coils to CDI causing it, but nothing definite. I'm no mechanic, so haven't a clue what those things are anyway Smile
Any help would be greatly appreciated.
Insanes Numquam Moriuntur
temeluchus
PostPosted: 13:44 - 20 Sep 2009    Post subject: Reply with quote
so it runs ok until about 70 then dies off until you go to 60ish?
Sounds like Fuel starvation or crap in the carbs.
Does the bike lurch or is it like the engine is switched off?
Try running the bike with the fuel tap on PRIME and try opening the fuel cap and listening for hissing noises. If you are running a fuel filter that may need changing. You can get a suitable filter for a few quid so its worth changing anyhow.
lonner
PostPosted: 13:52 - 20 Sep 2009    Post subject: Reply with quote
+1 to above for fuel filter or obstruction at the fuel tap Thumbs Up
EARTHWALKER
PostPosted: 12:27 - 22 Sep 2009    Post subject: Reply with quote
I checked the flow of the fuel and it's running very sweet. When I get the power loss, it will occasionally backfire so that also suggests the fuel is running correctly.
I have a CDI unit lined up and will fit it soon to see if that is the problem.
temeluchus
PostPosted: 13:20 - 22 Sep 2009    Post subject: Reply with quote
Aye could be a knackered CDI overheating i guess if the fuel is flowing ok.
Also check the coils as the suzuki ones are not great. I had a GSXR1100G (1986) which uses the same coils and they were not great.
EARTHWALKER
PostPosted: 22:56 - 22 Sep 2009    Post subject: Reply with quote
It does it in any gear and at any revs until whatever is making the spark stop. Normally around 60-70...ish
I have some coils lined up too as the ones on there are original, so a bit old and battered now. Hopefully these two parts will make her smile again, as there is no fun keeping at 60 on a motorway on my way to and from work.
temeluchus
PostPosted: 15:06 - 23 Sep 2009    Post subject: Reply with quote
The dyna coils are a good swap and fit in the same position as stock.
Accel coils also work but are big so need some inventiveness to fit.
Nology apparently make nice coils but have never seen one in the flesh.
The last post was made 16 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 52.25 Kb
