What revs?
Omar15
PostPosted: 12:52 - 22 Sep 2009    Post subject: What revs? Reply with quote
Right, so I got the restriction on my Hornet removed the other day. It feels like a rocket now! But obviously it revs a lot higher now and I was wondering - where should I be keeping the revs for most efficient riding?
On motorway riding it feels good to be holding them at about 8000 when im doing about 80/85mph - is that too high? Because then the bike's only in 3rd or 4th gear (3rd I think) and my experience makes me think I should have it in 5th and at lower revs.
Sorry, this is a pretty boring post but I'd appreciate any advice!
Omar
Mr.Everready
PostPosted: 12:55 - 22 Sep 2009    Post subject: Reply with quote
On the motorway there is no point having the bike in high revs, no for any length anyway. High gear and low revs.
Mystery
PostPosted: 13:27 - 22 Sep 2009    Post subject: Reply with quote
if your cruising on the motorway have it in the highest gear you can at probs about 80ish and keep your revs down and it will use less fuel
PostPosted: 06:04 - 23 Sep 2009    Post subject: Re: What revs? Reply with quote
No it doesn't.
Revs are a function of road speed and gearing. SInce you've just had the bike restricted it won't affect either of those things. So at 80 mph in stop it's still at the same revs.
I guess you mean to need to rev it more to make progress.
On the motorway you don't need the responsiveness of the engine anyway since you're sat at the same speed for so long. You may as well stick it in top and just sit there. If you're going along in third you're just using more fuel, and giving your engine a harder time than needs be.
Omar15
PostPosted: 09:26 - 23 Sep 2009    Post subject: Reply with quote
Cool, thanks guys. I guess I found that putting it in 5th at lower revs around 80 made it vibrate rather a lot, whereas a lower gear and higher revs felt smoother. Is there any reason for this?
Big_Ham - I'm not sure - I found with the restriction in the revs wouldnt ever go much above 5k. But maybe thats because I didnt make it...it sounded like it was dying.
thanks chaps
Omar
Finglonga
PostPosted: 12:37 - 23 Sep 2009    Post subject: Reply with quote
Sounds like your making the engine labour at lower speeds by changing up to early.
Andy Sez....
F.Y.Y.F.F.
Pie-Roe
PostPosted: 16:35 - 23 Sep 2009    Post subject: Reply with quote
I was under the impression cruising at 80mph in top putting revs at say 4k is labouring the engine more than at 6k.
Pyro
damz
PostPosted: 16:54 - 23 Sep 2009    Post subject: Reply with quote
i just cruise at 18,000rpm in 3rd gear on motorways, is that ok?
Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
The last post was made 17 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 55.96 Kb
