 Posted: 14:06 - 22 Sep 2009 Post subject: Alternative restrictor kit (CB500)? |
Ok, am I hell paying £175 to FI international for a restrictor kit consisting of 2 jets and 2 washers for the girlfriends CB500.
Given how FI seem to have a monopoly on them and can therefore charge what they want, I'm prepared to have a go at making one for myself.
I know they INCREASE the jet sizes from 122 to 125 (oddly).
Handily, I found a picture of the washers for this very kit (someone sold one on ebay, so it's a picture of the actual kit, not just a generic picture of restrictor washers):
https://i48.photobucket.com/albums/f216/stinkwheel/restrictor.jpg
So I'll be able to work out the ratio of outside to inside diameter from the picture.
Now all I need to find is the outside diameter, so I need to know where they fit in the air inlet (measuring this should give me the outside diameter) or is it safe to assume they are the same OD as the carb choke?
https://i48.photobucket.com/albums/f216/stinkwheel/carbrubber.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alex_H |
 Alex_H Borekit Bruiser
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 17:56 - 22 Sep 2009 Post subject: |
Judging by this thread, it sounds like the carb side of the inlet rubbers :-
https://www.bikechatforums.com/viewtopic.php?p=2173418 ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Noxious89123 |
 Posted: 18:47 - 22 Sep 2009 Post subject: |
On my CBR, there were just inside the ends of the inlet rubbers, where they meet the cylinder head. ____________________
 Posted: 19:31 - 22 Sep 2009 Post subject: |
So they go in the inlet manifold rubbers, not the airbox rubbers? Ahhh. That ought to be pretty simple then.
I make the hole in the washer 0.84 (+or- 0.5mm) of the outside diameter. So I make a washer that is a tight fit in the rubber, measure its OD and make a hole 0.84 times that size in the middle.
Slight error on the sizes but it's a safe bet that at 24k miles, it isn't making the same power as a new one anyway, which is what the restriction will be calculated on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 17 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
