FZR600 won't run above 1/4 throttle
Cetrinite
PostPosted: 04:42 - 23 Sep 2009    Post subject: FZR600 won't run above 1/4 throttle Reply with quote
My 95 FZR600 coughs and bogs and will not run out above 1/4 throttle. Removed the carbs, totally cleaned, have played with the air/fuel screw, blocked off the intake, opened the intake... Ignition? Starts easy, idles great, runs great up to 1/4 throttle, will tach out to 7 or 8 grand if you have a long enough road. Jetting?
Ideas please, thanks Owen.
Cars Suck
temeluchus
PostPosted: 15:07 - 23 Sep 2009    Post subject: Reply with quote
check your fuel tap and filter if fitted. Also take the bike for a spin with the fuel cap open-there is a breather in the cap that if blocked impedes fuel flow. If its there set your tap to PRIME and see if that cures the issue.
tutton
PostPosted: 15:21 - 23 Sep 2009    Post subject: Reply with quote
dont have taps they have switch on or reserve.
coils on mine made it run shit and fired bad alot,
sorry cant be of any more help
KevTM
PostPosted: 17:06 - 23 Sep 2009    Post subject: Reply with quote
Does it have the proper airbox and filter?
temeluchus
PostPosted: 17:41 - 23 Sep 2009    Post subject: Reply with quote
yeah FZRs run like crap if the airbox isnt fitted perfectly.
Cetrinite
PostPosted: 22:06 - 23 Sep 2009    Post subject: Reply with quote
Thanks for your replies.
I removed the fuel tap (petcock) and cleaned it out, working well. Tested it w/o the fuel cap, runs the same.
Has the stock airbox/filter, tested it with intake partially blocked and removed the filter and then removed the entire box... runs the same all ways.
Coils? Does anyone have the OHM specs, I'll test them that way. However I imagine that coils only work or do not work... that's what Yoda says anyway.
Could it be the jet needle setting (too high, too low) ? I did not check it when I had the carbs off. BTW it does have the factory jets.
Thanks, Owen.
Cars Suck
PostPosted: 10:14 - 24 Sep 2009    Post subject: Reply with quote
Another thing to check is that the diaphragms in the carbs are all in decent condition. If they are perished them the slides won't lift.
Cetrinite
PostPosted: 02:36 - 25 Sep 2009    Post subject: Reply with quote
Thank you for your ideas, Owen.
Cars Suck
The last post was made 16 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 56.17 Kb
