| trisers |
 trisers Scooby Slapper
 Posted: 15:01 - 21 Sep 2009 Post subject: |
You need to stop the damper rod it bolts into turning. You can often get away with this but undoing the bolt while the springs are still in place (the spring pushes on the damper rod and helps it not turn). This appears to be the proper way to do it according to the Honda H100A manual
You might be able to to it by pulling the forks apart with a bit of force and undoing the bolt while doing this (ie, hopefully the force stops the damper rod spinning when the bolt is turned).
You might also be able to use something down the middle of the fork to stop it turning. Normal trick is a wooden broom handle but the H100 forks are probably too narrow for that.
| trisers |
 ---- World Chat Champion
| G |
 G The Voice of Reason
 Posted: 18:38 - 23 Sep 2009 Post subject: |
From what I remember, I used a fork and some L-section shelving bracket on my zx9 once.
These days I just use an electric/air impact wrench, which is much easier . |
| trisers |
 Posted: 19:04 - 23 Sep 2009 Post subject: |
This is the damper rod from the original fork and as you can see there's no shape in the head of it to grip with any tool that springs to mind
https://i2.photobucket.com/albums/y27/clivejameson/IMG_2829_1.jpg
I'm beginning to wonder if i can fit a suitably sized screw extractor to attach to the end of my piece of rod and get it to 'bite' down the centre of the tube? |
 Posted: 19:38 - 23 Sep 2009 Post subject: |
For that type i would use a long bar filed (grinder) to a point with 4 sides.
Hammer the bar in and the 4 points should dig in enough to unscrew the bolt.
(Not saying this is the right way to do it,just the way that i do it.)
There is a gap of 1 year, 230 days between these two posts... |
| trisers |
The last post was made 15 years, 163 days ago. Instead of replying here, would creating a new thread be more useful? |
