Restoration
That_Hornet
PostPosted: 21:27 - 21 Sep 2009    Post subject: Restoration Reply with quote
Got a XS750 in a sorry state.
Idea being to get it running at turn it into a rat bike...
A few questions before i start.
Arrow Engines oxidised, whats the ideal method to remove this without spending £££. Could i get a good result by just using a High ph liquid and a bit of elbow grease?
Arrow Air cooled engine, I would idealy like to paint it black. So my thought would me painting it in a high temp paint. But would this act as an insulator and result in a big bang? Or would it be ok?
Arrow With regards to the frame. could this also be just rubbed down then painted out of the spray tin. or would it be a bit of a cowboy job?
Arrow First point of call to get the engine running again. Would i be right in thinking i should start by getting a battery on it and obviously replacing the oil, petrol, and filters. Then checking i get a spark?
If anyone could shed some advice on the subjects. I would be very much appreciated Thumbs Up Karma
effit
PostPosted: 08:23 - 22 Sep 2009    Post subject: Reply with quote
Google "osborn pro wire wheel" Its like a wire brush in the shape of a grinding disc. It will fit on to your grinder and you can apply more power than using a drill.
Also, my old man has one of these bikes and the plugs seized in the engine. It had lay for a year or so but the plug actually snapped in the engine. Total bastard to rectify so its just a suggestion to try before you start all that hard work
Good luck fella... Thumbs Up
That_Hornet
PostPosted: 18:05 - 23 Sep 2009    Post subject: Reply with quote
Ok, Mr. Green
How did he go about getting it out?
Its snapped flush with the engine. Is it going to be a case of taking the head off and drilling out from the inside or what?
Thanks Again
temeluchus
PostPosted: 18:58 - 23 Sep 2009    Post subject: Reply with quote
if you have the inner bit (ie nothing has dropped into the cylinder) and its just the threaded portion, you can use a large easy out to remove it.
That_Hornet
PostPosted: 19:39 - 23 Sep 2009    Post subject: Reply with quote
Easy out? Embarassed
Alex_H
PostPosted: 20:04 - 23 Sep 2009    Post subject: Reply with quote
easy out, stud extractor, https://cgi.ebay.co.uk/8-pc-DAMAGED-SCREW-BOLT-REMOVER-EASY-OUT-STUD-EXTRACTOR_W0QQitemZ400074589288QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?hash=item5d264dc468&_trksid=p3286.c0.m14
worth paying more to get a good set though.
1998 r1, ccm 644 ds, 2000 r6 ghetto track bike
That_Hornet
PostPosted: 20:22 - 23 Sep 2009    Post subject: Reply with quote
I can see me using them alot.... How much would you recomend for a decent one? £15~£20??
Thanks Thumbs Up
That_Hornet
PostPosted: 20:23 - 23 Sep 2009    Post subject: Reply with quote
Thanks Thumbs Up
That_Hornet
PostPosted: 20:27 - 23 Sep 2009    Post subject: Reply with quote
Thanks Thumbs Up
PostPosted: 20:39 - 23 Sep 2009    Post subject: Reply with quote
Thanks Thumbs Up
That_Hornet
PostPosted: 20:58 - 23 Sep 2009    Post subject: Reply with quote
Wow... 3... Embarassed
temeluchus
PostPosted: 12:04 - 24 Sep 2009    Post subject: Reply with quote
youll probably need a 8-10mm one. A quality one on its own from a reputable tool shop will be a few quid.
ZRX61
Victor Meldrew
PostPosted: 15:18 - 25 Sep 2009    Post subject: Reply with quote
CHR15 wrote:
sandblast, or drill with wire wheel, or wirebrush
NOT sand FFS Rolling Eyes
ZRX61
Victor Meldrew
PostPosted: 15:20 - 25 Sep 2009    Post subject: Reply with quote
Thanks Thumbs Up
Also look into what it takes to remove a snapped EZ out.. you WILL break them.
The last post was made 16 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.16 - MySQL Queries: 15 - Page Size: 82.82 Kb
