Slow puncture in front tyre.
PostPosted: 04:07 - 25 Sep 2009    Post subject: Slow puncture in front tyre. Reply with quote
Is there anything I can do? a new one is £95 + fitting and the current one is only half worn. I don't think it is the valve although it is hard to tell and the valve points sidewards and I can't gob into it . I was thinking maybe tyre weld of something but I don't think it is designed to fix slow punctures.
Aka Matt
PostPosted: 07:36 - 25 Sep 2009    Post subject: Reply with quote
Take it to a tyre repair place and they will be able to tell you where it is. I had one looked at yesterday on my thundercat as I couldn't for the life of me find the bastard puncture so thought maybe it was the valve or the tyre incorrectly seated on the rim. Turned out I had the worlds most pathetic puncture in the tyre Sad.
But if I were you I would definitely get it checked out by a pro if you are unable to locate it before trying anything like slime, tyre weld etc in the tyre just so you are aware of where it is because if it is the valve, it can always be replaced.
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
binge
Emo Kiddy
PostPosted: 09:37 - 25 Sep 2009    Post subject: Reply with quote
I can't check because im at work on my phone. But if you are local to medway come see me, i'll plug it for you, or change the valve if its that.
by the sounds of it you have a 90 degree bend in your valve, in which case i suspect its got an innertube.
jay12329
Dr. Evil
PostPosted: 10:14 - 25 Sep 2009    Post subject: Reply with quote
Its prob just the valve, drop the wheel off and pump up tyre add water to valve and it will prob bubble. take it to your tyre man with 50p and he will tighten or replace the valve if needed.
J
The last post was made 16 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 40.02 Kb
