CG 125 Brake Shoe Sizes
catceefer
PostPosted: 18:51 - 25 Sep 2009    Post subject: CG 125 Brake Shoe Sizes Reply with quote
Does anyone have a spare brake shoe to hand to measure? I would like to know the surface area of the brakes to compare with my current set up.
Any help that can be given would be appreicated.
Thank you.
James.
Regards,
James.
PostPosted: 20:46 - 25 Sep 2009    Post subject: Reply with quote
Oddly enough, I do. There's a set sitting just downstairs.
The total area of pad material on each shoe is 115 x 24mm. However, each end of the friction material is chamfered to prevent grabbing.
The actual area of friction material that contacts the drum will depend on how much chamfer there is and how worn the pad is. I usually make a bit more of an obtuse angle at the leading edge so it tapers slowly up to the working part of the pad with some course emery paper because I don't think there is enough of a chamfer.
The one I measured is down to the wear limit and has 98 x 24mm of working pad material in contact with the drum.
catceefer
PostPosted: 21:35 - 25 Sep 2009    Post subject: Reply with quote
Thank you. My C15 has a total square area of 5,600mm compared with 5,520mm on the CG125. On size of shoe alone, there shouldn't be a lot of difference. I suppose the difference will be in the design of the actuating mechanism and the only way I will really know which is better is to fit one and try.
Regards,
James.
Regards,
James.
The last post was made 16 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 35.94 Kb
