| oldie biker reborn |
 oldie biker reborn Derestricted Danger
 Posted: 13:38 - 27 Sep 2009 Post subject: help for a honda cb125td-c |
i am having to take my bike test again!! dvla removed some years ago, i actually passed it in 1969, so i got a cb125td-c for £100, it needs some work, and money is tight at the mo, i have done some tinkering work on it, got the engine to start, new plugs strip carbs, had to buy a pilot jet for left pot, but its still misfiring on right, give it a handful up a private road and she`s off, should i have bought 2 pilot jets? if anybody out knows where i can get spares from please let me know, breakers yards and the like.
thanks. dave  |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:53 - 27 Sep 2009 Post subject: |
Swap the pilot jets over - if the new one cures the right misfire, you know you need another one
As far as spares are concerned, give David Silver a try :-
https://www.davidsilverspares.co.uk/parts/ ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
 Posted: 14:05 - 27 Sep 2009 Post subject: |
"90% of carb problems are electrical".
Handily, everything in the ignition system is seperate for the two sides of the engine, it has two CDI units, two pickups, two coils. You can swap parts from one side to the other until the misfire changes sides, then you know where the problem is. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 15:30 - 27 Sep 2009 Post subject: cb125td-c |
thanks for that shaggy/stinkwheel, i have changed the plugs,cdi units ht leads around first thing i thought of, its a bit of a clack stripping both carbs down, again, but i`ll give it a go, thanks for the web address for spares shaggy i will log on tomorrow.
cheers guys :  |
 Posted: 16:40 - 27 Sep 2009 Post subject: |
I remember on my one that the carb needles used to come adrift from the throttle bodies very easily if you didn't get them in bang-on square fitst time. They're just held in with a little spring clip, if you caught the needle on the side of the main jet hole, it'd push out of place and rattle about loose. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 16 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
