Making my own trackday fairings!
AngelGrinder
PostPosted: 15:06 - 29 Sep 2009    Post subject: Making my own trackday fairings! Reply with quote
At the start of the year I was forced off the road by a kind person in a people carrier, which ended up in the front and rear fairings being damaged, and then left to sit in the garage.
While sourcing replacement parts, someone had some rashed side fairings to sell aswell, so after buying those, I had a full set of spare (but damaged) plastics.
I bodged most of it together for the trackdays in summer, and while they did the job, they didn't look so great. So, over the winter I'm going to (try) and make them alot better.
I already have used fiberglass and filler to fill the headlight holes in, but will be re-doing the whole lot over winter as they weren't great.
Once they are all done, I will be taking them to my dad's to use his compressor to spray them!
Anyway, I havn't really done this before, so feel free to offer advice!
All cracks and breaks have been repaired using either or a combination of P40, araldite and a soldering iron.
So, today I decided I want to get rid of the pillion seat, and create a one piece seat fairing.
To start I go the rough shape that I needed with some aluminium mesh, and used a staple gun to fix it in place.
https://i6.photobucket.com/albums/y209/angelgrinder187/DSCF1903.jpg
https://i6.photobucket.com/albums/y209/angelgrinder187/DSCF1904.jpg
Next I used 2 bits of wooden dowel to allow me to screw the fairing on, I obviously didn't want to no be able to attach the fairing, so the dowel leaves the 2 holes needed to do this. In the future I am hoping to find a plastic tube or similar that fits in and I can glue in.
I attached the dowel to the fairing mounting points at the bottom with screws and washers, and covered the wood in a rubber glove so I can get it out when the fibreglass has set!
https://i6.photobucket.com/albums/y209/angelgrinder187/DSCF1905.jpg
https://i6.photobucket.com/albums/y209/angelgrinder187/DSCF1906.jpg
Next comes the fun/annoying part...fibreglassing. This stuff is amazing....but so annoying, it goes everywhere!
https://i6.photobucket.com/albums/y209/angelgrinder187/DSCF1907.jpg
https://i6.photobucket.com/albums/y209/angelgrinder187/DSCF1909.jpg
Will see how it looks when it's dried, then I'll see if it needs more fibreglass, or if I shall start applying the filler!
Any tips or advice from anyone?
Also, I'm not bothered about weight or anything, I'm just into trackdays and want them as a cheaper option than crashing in my road plastics! And I'm bored and wanted to have a go/learn some new stuff!
Whosthedaddy
PostPosted: 15:57 - 29 Sep 2009    Post subject: Reply with quote
Looking good so far.
Gazdaman
I did a trackday!!!
PostPosted: 16:05 - 29 Sep 2009    Post subject: Reply with quote
Looking good, it's easy to make fibreglass look really really bad.
This is an attempt a mate of mine made. It's a Corn Flakes box underneath.
https://photos-f.ak.fbcdn.net/photos-ak-sf2p/v71/142/44/518180216/n518180216_271981_3332.jpg
Gaz
Simple
PostPosted: 01:07 - 01 Oct 2009    Post subject: Reply with quote
Gaz
when I told him to use a cereal box as a mould I didn't mean use it as a structural part of the fairing. Laughing bless his blondness
Insta - FemFeral
AngelGrinder
PostPosted: 21:15 - 01 Oct 2009    Post subject: Reply with quote
I like the cereal box Laughing Would have probably been alot less messy than the aluminium mesh - all the resin seeped through and is everywhere!
Also, we have already reached problem number one....not enough hardener. It was still sticky yesterday, but seems ok tonight, going to give it another day to harden, hopefully will be ok to start sanding tomorrow!
Also, had a panic when I realised the subframe may not fit into the new space, but I have checked and we are all good!
PostPosted: 09:12 - 02 Oct 2009    Post subject: Reply with quote
Looking good.
Reminds me I need to spray mine actually. A trip to Halford is on the cards. Very Happy
Simple
PostPosted: 17:38 - 02 Oct 2009    Post subject: Reply with quote
yes it is!
they've reduced their 150 piece socket and spanner set to £100 online and if the counter person is a bit stupid in store you also get a tool chest with a store purchase.
so reserve (save £100) and go pick up..get free tool chest (£150)
win win
Insta - FemFeral
TimNorwich
PostPosted: 19:45 - 05 Oct 2009    Post subject: Reply with quote
Gotta love Pauls cereal box, kellogs?
Resident Yank
PostPosted: 22:37 - 05 Oct 2009    Post subject: Reply with quote
Good job on the single seat cowl, it looks like it will come out quite nice. I have to make an undertail for an SV race tail and that mesh has given me some ideas. Just for future reference another way that a mold can be made is to make a rough frame using wooden dowels, bits of metal, or even cardboard, then stretch fleece over them. This will give you a very flat, uniform surface that is sometimes hard to get with a mesh that tends to bend. You then soak the fleece in fiberglass resin and let it harden. From there lay up a few layers of glass to strengthen it and move on with your body filler. Many custom speaker box builders here in the US use this method. Also... there is a product that is called "kitty hair" in the US, I'm sure you have an equivalent over there, its basically a glass fiber reinforced body filler. Use this to build up any large areas, more durable and chip resistant than regular body filler, especially if you are going over 1/4 thick. I just used it to fill in voids when fitting a GSXR 750 windscreen to an SV650 front race fairing. Its good stuff.
Snooping in from the US, don't kill me.
AngelGrinder
PostPosted: 08:06 - 06 Oct 2009    Post subject: Reply with quote
Thanks for the advice, I'm still in the process of cleaning up the fairing ready for fillering - I made a right mess of the fiberglass resin!
The 'kitty hair' you talk about, I think it's called P40 over here, it's basically fibreglass putty that you mix with hardener.
AngelGrinder
PostPosted: 08:59 - 06 Oct 2009    Post subject: Reply with quote
Oh, and this is probably how the paint scheme will look...
https://i851.photobucket.com/albums/ab71/MattRock77/sol_daytona.jpg
Mystery
PostPosted: 11:59 - 06 Oct 2009    Post subject: Reply with quote
for a yellow bike that doesn't look to bad Thumbs Up
Resident Yank
PostPosted: 13:51 - 06 Oct 2009    Post subject: Reply with quote
No prob. Yes... the first many times I worked with fiberglass I made a HUGE mess. Ended up with resin all over my arms, clothes and had resin and fibers stuck to my gloves, not to mention covering everything within 3 feet of my work area along with resin fingerprints on everything. I've decided there is no "clean" way to work with it, you just have to organize your work area so that you make the smallest mess possible. Its fun though and I would play with fiberglass all day if I could.
Your paint scheme looks very nice. Can't wait to see the finished product.
don
PostPosted: 01:16 - 13 Oct 2009    Post subject: fibreglass Reply with quote
Hi, looking good!
The reason some fibreglass feels sticky is there are two kinds, those with a surfacing wax and those without, this is to make a film over the grp to get it to set properly.You can get over this by covering it in some plastic,before it sets, then removing it when its set, but using a random orbital sander will take the stickyness off.
If you cover the grp or p40 with clingfilm you can use a straight piece of wood, or a template to help push and shape the grp. you have to sand off the clingfilm but it saves a lot of shaping and fillers.You can also use bendy plastic which has been waxed,and gaffa tape, but do not use any polish with silicone in it.floor polish works, or turtle wax.
You can use a waxed plastic sheet as a mould, apply grp to the sheet, then bend,(pre score with a knife or heat up if needed) onto the seat, plastic side down, grp up,errr...with the seat upside down... gaffa or bungee on, when set, trim up.This gives a flat surface which is much easier to work on.
As p40 sets quite quickly, you could do the seat top first, then trim off, then do the sides, it keeps you focused on one area and is less messy than the "octopus wrestling" that can happen!
Best of luck
cbr600
Pussy Magnet
PostPosted: 08:36 - 21 Oct 2009    Post subject: Reply with quote
thats is such a good topic just keep laughing when i see the pciture and when you look you can actaly tell its a cereal box Laughing
don This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
AngelGrinder
PostPosted: 10:44 - 18 Dec 2009    Post subject: Reply with quote
Just a quick update...I am seriously fed up with this now Laughing
Got the fiberglass and filler to have it smooth, but it wasn't flat, so I bought some plastic sheet used for modelling, and it's flat now, but no matter how miuch glue, fiberglass or filler I use, the edges still keep peeling off...
Anyone got a 675 rear seat unit to sell? Laughing
Bishbash
PostPosted: 16:53 - 18 Dec 2009    Post subject: Reply with quote
What? I just read all that to see you're giving up....That's lame dude. Tut Tut
Come on, I want to see this done....No-one likes a quitter. Razz
AngelGrinder
PostPosted: 17:20 - 18 Dec 2009    Post subject: Reply with quote
But....I am lame. Laughing
We will see how bored I get, or how cheap a fairing turns up on ebay...this will decide the winner.
Oh, I'd also like to add, it's become about as heavy a bag of sand.
Mystery
PostPosted: 20:01 - 19 Dec 2009    Post subject: Reply with quote
not that i like saying this but i'm sure some bikers will smash a few bikes up over the winter so you might get one Thumbs Up
AngelGrinder
PostPosted: 21:31 - 20 Dec 2009    Post subject: Reply with quote
Currently have a vinyl guy working on the design, this is how it's looking currently....
https://i6.photobucket.com/albums/y209/angelgrinder187/Mock_up_1st_Draft1.jpg
Bishbash
PostPosted: 09:36 - 21 Dec 2009    Post subject: Reply with quote
I love that paint job, hope you get it done! Good luck too.
Resident Yank
PostPosted: 17:23 - 22 Dec 2009    Post subject: Reply with quote
Hi there, what do you mean the edges still keep peeling off? You mean where you are trying to blend the new cowling into the plastic on the tail? If i weren't across the pond I'd offer to help you finish it up as its a great project.
The last post was made 16 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 129.72 Kb
