speedfight 100 smoking alot
mark1992
PostPosted: 17:47 - 29 Sep 2009    Post subject: speedfight 100 smoking alot Reply with quote
hi there i have a speedfight 100 and it seems to smoke alot but doesnt splutter or big. it also starts first time everytime. its worrying me with the amount of smoke but apart from the smoke it runs spot on. what could be wrong? thanks
Irn-Bru
PostPosted: 18:56 - 29 Sep 2009    Post subject: Reply with quote
Does it smoke loads after you've been using it for a while? What 2-stroke oil do you use? The cheap stuff tends to be smokey.
EDIT: that's if it's a 2-stroke Laughing
PostPosted: 19:21 - 29 Sep 2009    Post subject: Reply with quote
It is a 2 stroke, and the cheaper oil being smokier is a myth.
mark1992
PostPosted: 19:35 - 29 Sep 2009    Post subject: Reply with quote
well ill run it up and down the road about 7 times and its still smoking. im not sure what oil is in the bike. would the air screw make it smoke?
PostPosted: 22:41 - 29 Sep 2009    Post subject: Reply with quote
No.
mark1992
PostPosted: 06:11 - 30 Sep 2009    Post subject: Reply with quote
ok well is this a major problem that the bike is smoking alot? its not clouds of smokes but its enought to keep me worrying. i dont understand why the bike runs spot on tho?
mark1992
PostPosted: 06:15 - 30 Sep 2009    Post subject: Reply with quote
basically when i first got the bike which was about a month ago i went to start it a few days after and it wouldnt, the spark plug was clogged with black sut. i cleaned it and it started spot on. i fiddled with the air screw and it made it run fine. how do you set the air screw properly? anyway could the reason its smoking be from all the sutt and oil its built up in the engine and in the exhaust?
mark1992
PostPosted: 06:02 - 01 Oct 2009    Post subject: Reply with quote
anyone have an idea? thanks
smegballs
PostPosted: 08:53 - 01 Oct 2009    Post subject: Reply with quote
Maybe the price of oil isnt the smoke deciding factor, but in my experience certainly different brands of oil have different smoking attributes. Although price doesn't seem be a factor.
temeluchus
PostPosted: 11:13 - 01 Oct 2009    Post subject: Reply with quote
Change the air filter would be a start if fiddling with the pilot air screw made it run better. If its blocked then not enough air gets in and the extra vacuum it creates makes the carb dump yet more fuel into the motor.
Also Id suggest getting hold of a manual to see what the correct number of turns it is for the pilot screw.
That_Hornet
PostPosted: 21:52 - 01 Oct 2009    Post subject: Reply with quote
Old lambrettas smoke.
Following one home the other day. Didnt overtake just sat behind. Went the long way home aswell.
2 stroke smells good. Mr. Green Thumbs Up
prawny1
PostPosted: 15:44 - 03 Oct 2009    Post subject: Reply with quote
As far as i can remember the speedy's have a cable operated oil pump towards the rear of the engine can't remember which side, So you could check that the pump is set right and that the cable/ pump operate freely, I could be that the pump is stuck full open or that the cable isn't returning fully with the throttle closed.
Most two strokes will smoke but not realy heavily, unless someone has put oil in the fuel tank as "a bit of extra protection" or accidebtaly put some diesel in, seen that a few times with the Usualy accompanied by "It was running sweet then i filled up and it started smoking and now it won't start", I make a point of smelling the petrol tanks in not running mopeds now just in case.
The last post was made 16 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 77.15 Kb
