Theoretical thinking - turbo's
PostPosted: 00:20 - 01 Oct 2009    Post subject: Reply with quote
You can fit as many as you want, in the same way you can fit as many carbs as you want doesn't mean it's a good idea.
PostPosted: 00:21 - 01 Oct 2009    Post subject: Reply with quote
You could, but suspect no great benefit. Not certain but think you would need a pretty small turbo, and suspect that the efficiency of the turbo drops off on a smaller diameter turbine. Also suspect that with a single cylinder powering a turbo you would land up with seperate pulses in the exhaust gas which the turbo probably wouldn't appreciate.
Plenty of engines have 2 turbos. Bugatti EB110 was a V12 with 4 turbos.
calyx
PostPosted: 01:20 - 01 Oct 2009    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Twin-turbo
Boris - London
Alexio
PostPosted: 02:20 - 01 Oct 2009    Post subject: Reply with quote
The question I would ask is:
Are there four separate air intakes (and air filters) for a four cylinder engine? I honestly don't know but I would assume not.
PostPosted: 04:23 - 01 Oct 2009    Post subject: Reply with quote
Depends, on most cars no. Most bikes have separate carbs/injectors but pull air from the air box
B5234FT
PostPosted: 07:34 - 01 Oct 2009    Post subject: Reply with quote
You can, but as said, its of no great benefit. you're better pairing cylinders to get an exhaust pulse twice as often at the bare minimum and even if you consider that its often just as good a result if a single turbo is used and then you only have one intake, throttle body, oils feed......
many twin turbo applications are done for packaging rather than overall effect i.e. a V8 single turbo is very hard to engineer
Cptn. Awesome
PostPosted: 07:45 - 01 Oct 2009    Post subject: Reply with quote
From what I can imagine it may make power ridiculously lumpy. Hellishly fun though, I'd imagine. From what people have said it would seem that a better idea would a minimum of two different pulses per turbo, so a turbo per 2 cylinders.
Rides - '60 Plate Ford Fiesta Zetec 1.25, '03 Plate Kawasaki ZX6R B1H and an '87 VFR400 NC24
Naughty Fawbish: "An eagle is but an eagle until the suns flare blinds his prey." - Fawbish, 2010.
PostPosted: 09:13 - 01 Oct 2009    Post subject: Reply with quote
No it wouldn't work.
A turbo works best with a constant stream of exhaust gases. Individual cylinders send out pulses, but with four cylinders you get a much smoother flow of gas which gives much more consistent boost.
I suspect the best efficiency from a turbo is given by a 6 or 8 cylinder engine with the right firing order, and a single turbo. The best efficiency however doesn't necessarily mean the smoothest power delivery or the least lag, hence why some car manufacturers fit a small and large turbo for different parts of the rev range, and even twincharge (which is a supercharger and a turbo).
Not really practical on a bike though.
Ol
PostPosted: 14:02 - 01 Oct 2009    Post subject: Reply with quote
As keith said, there's quite a few modern car's with a few turbos - completely unglamourously, my dad has just got a new BMW123 M-Sport Coupé, that has a 2.0L Twin Turbo Diesel engine and is claimed to be good for 210bhp, has one main large turbo, and a smaller turbo running consecutively to reduce lag
incidentally - quite a nice, nippy car really.
lilredmachine
PostPosted: 15:54 - 01 Oct 2009    Post subject: Reply with quote
Is it easy as ABC?
You can, here is a video of a custom 8 turbo v8 Chevy on the dyno.
https://www.youtube.com/watch?v=kxdH4zb9eCs&feature=related
And here it is in the car.
https://www.youtube.com/watch?v=bLfujQrr2yA&feature=related
and here it is with a few better pics.
https://www.youtube.com/watch?v=pbu8KLQTdKo&feature=fvw
As ever, if it's dumb enough, an American has probably wasted a lot of money doing it.
PostPosted: 10:26 - 02 Oct 2009    Post subject: Reply with quote
the warped one wrote:
Thanks kickstart, but would it work in thoery if you had the right setup and everything would it give better boost over your standard turbo/twin
I suspect it would be worse. I suspect that you would land up wanting to use such small turbos to get them to spool up adequately quickly that they would not give brilliant boost at higher rpm. Also you need to account for the pulses in the exhaust delivery.
thewildblue
PostPosted: 12:23 - 02 Oct 2009    Post subject: Reply with quote
The old RX7 twin turbos had 1 turbo per cylinder...well per rotor...even though it was one for low to mid and the other for top end....and you can make them sequential if you want....
PostPosted: 19:17 - 02 Oct 2009    Post subject: Reply with quote
Simple answer is that one larger turbo is more efficient than two smaller ones, unless they are compounded which isn't any use on a roadbike. Why add complexity and weight for a less-efficient package?
The last post was made 16 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 89.57 Kb
