stupid idea may work cg125 in ns125r ? will it work just now
bradh511
PostPosted: 22:07 - 01 Oct 2009    Post subject: stupid idea may work cg125 in ns125r ? will it work just now Reply with quote
from what ive seen of the cg motor mounts are the same ive got engine running with carb and coil diffrent throttle cabel just use my twist throttle wireing isnt the problem its my exzaust i would have made a tube exhaust and put a can on the back but i dont have the down pipe any ideas as my bikes at garage gona get it monday when i get this engine
PostPosted: 07:48 - 02 Oct 2009    Post subject: Reply with quote
i think he wants a cg engine in an nsr frame...
dunno about you but in my opinion that would suck.
Just use the NSR as it is, or CG as it is, no point pissing around for 4 weeks Razz
bradh511
PostPosted: 20:25 - 02 Oct 2009    Post subject: Reply with quote
i have an old ns the motor 2 stroke one was fully rebuilt i have a cg motor brazil that has the coil the lot all i will need to do is find the chargeing waires and connect them into my loom i was wondering anyone know on weather the mounts are 100% the same or wopuld i need to make adapter its only till i get my engine back becuase there be another month doing it again and it will be 2 month tax mot and insurance wasted and will my exzaust fit
Damon
PostPosted: 11:40 - 04 Oct 2009    Post subject: Reply with quote
nope, dont do it
Ariel Badger
PostPosted: 12:11 - 04 Oct 2009    Post subject: Reply with quote
whatever you are trying to do do not do it.
Finglonga
PostPosted: 12:50 - 04 Oct 2009    Post subject: Reply with quote
It's like reading (or trying) a question from Yahoo Answers!
FFS use the https://img.photobucket.com/albums/v112/finglonga/Spellcheck.jpg!
Andy Sez....
F.Y.Y.F.F.
PostPosted: 13:10 - 04 Oct 2009    Post subject: Reply with quote
Very much doubt the engine mounts are the same, and even less likely the electrics would be easy to connect up. Add in the cost of getting spacers made up, suitable sprocket for the CG engine to match up with the NS back wheel, exhaust, etc.
While it is probably possible is would alsmost certainly be a lot cheaper and easier to buy several spare decent NS engines.
bradh511
PostPosted: 17:54 - 04 Oct 2009    Post subject: Reply with quote
i dont need electrics that all been done i have an ffreind who will make the exzaust for free just the mounts i think are the same ive got to get my bike so it rideable for next to nothing becuase im stuck with no money and garage will be over a month rebuilding the 2 stroke .ohh and sporket i can use off the ns engine
and dont worry the ns orignal engine will be back in it asap
binge
Emo Kiddy
PostPosted: 18:05 - 04 Oct 2009    Post subject: Reply with quote
Just slap the NS reg plate on your CG for a few weeks. And don't be a cock on it.
PostPosted: 18:14 - 04 Oct 2009    Post subject: Reply with quote
You have managed to wire up a CG ignition system (cdi and all) along with the regulator / rectifier to the NS loom?
Pretty unlikely to be honest. From memory even the MBX125 engine (the predecessor to the NS) which had a fairly similar engine would need different size spacers for the engine mounts than an NS.
I would also expect the CG engine to be quite a bit taller.
Damon
PostPosted: 19:00 - 04 Oct 2009    Post subject: Reply with quote
Surely if you have done the electrics you would be more than able to work out where the engine mounts are on both bikes...
salty21
PostPosted: 19:22 - 04 Oct 2009    Post subject: Reply with quote
here you go. Try some of these Thumbs Up
The last post was made 16 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 78.57 Kb
