exhaust restricted?
speedjunkie20...
PostPosted: 11:27 - 04 Oct 2009    Post subject: exhaust restricted? Reply with quote
Does anyone know if the big one exhaust for a dt 125 comes with a restrictor or not. my bike is still only hitting 65 70 with a big one exhaust, and powervalve opened.
PostPosted: 13:21 - 04 Oct 2009    Post subject: Reply with quote
Not certain but would think it is very unlikely.
redline
PostPosted: 19:30 - 04 Oct 2009    Post subject: Reply with quote
None of the ones I have ever had did, they are an expansion chamber. Have you got the front pipe and tail pipe? If you have you could experiment with different sized jets, although you shouldn't necessarily have to do this, otherwise you could try a different front or rear sprocket
Hope this helps
Jamie S
PostPosted: 20:16 - 04 Oct 2009    Post subject: Reply with quote
As a side note, Whats a realistic top speed for a DT ?
Ive got a 1999 dtr, fully functioning power valve , reducing washer took out from the very front of the spanny and the airbox snorkel is took off.
It will sit at 65/70 , can be pushed to show 80 on the clocks given a slight gradient and long enough road.
Going to stick it on the dyno soon to see what bhp its making, what would be about right for one ? around 20 odd ?
Regards, Jamie
That_Hornet
PostPosted: 20:17 - 04 Oct 2009    Post subject: Reply with quote
https://www.dtr125.net/ Thumbs Up
prawny1
PostPosted: 01:57 - 05 Oct 2009    Post subject: Reply with quote
are you reaching red line in top gear?
if so try a bigger front sprocket, it will give you a little more top speed if your still revving out try a tooth smaller on the rear
PostPosted: 20:38 - 05 Oct 2009    Post subject: Reply with quote
Sounds about what I would expect from a restricted one. True around 65 or so, indicated a bit more, even more down hill.
stevo as b4
PostPosted: 21:58 - 05 Oct 2009    Post subject: Reply with quote
It does depend on the gearing TBH. It should be geared for 80-85mph at 10.5k i would have said. You would expect around18-20bhp for a full power DTR at the back wheel, but it depends on if you have other mods like an aftermarket pipe etc.
With full power versions you can usefully raise the overall gearing slightly for more speed. All trail bikes are compromised by their std gearing. The KMX125's will do another 5-6mph with just a 1t bigger front sprocket for example.
The last post was made 16 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.64 - MySQL Queries: 13 - Page Size: 56.63 Kb
