Are DID chain's really that superior?
AngelGrinder
PostPosted: 08:49 - 06 Oct 2009    Post subject: Are DID chain's really that superior? Reply with quote
I'm in desperate need of a new chain, but money is tight at the moment, and just looking at a chain, the DID X-ring is £20 more expensive than a TSubaki X-ring.
Is it worth the extra £20?
Anyone had experience with either?
PostPosted: 08:58 - 06 Oct 2009    Post subject: Reply with quote
I've run DID chains and noticed no difference to any other big name chain maker.
the grim reaper
PostPosted: 09:13 - 06 Oct 2009    Post subject: Reply with quote
The only brand I've ever heard of any issues with is Triple S, you may get better longevity with the more expensive chain but if money is tight then either would suffice.
Grim
R6Armadillo
PostPosted: 09:24 - 06 Oct 2009    Post subject: Reply with quote
I've always used TSubaki X-ring chains and also fitted them to mates bikes, never had any problems with them at all.
When Eric eats a banana, an amazing transformation occurs. Eric is Bananaman. Ever alert for the call to action.
craigs23
Mr Muscle
PostPosted: 10:08 - 06 Oct 2009    Post subject: Reply with quote
I've had Tsubakis in the past. No difference with one and a DID, apart from the free £20 beer token that comes with each purchase.
Jenks
PostPosted: 13:02 - 06 Oct 2009    Post subject: Reply with quote
ive used a few - Vortex, Ts, DID to name 3..
Again, the only one ive heard of trouble with, was Tripple S. My friend snapped 2 within the space of a week on his Firestorm (first replaced by bike shop) and the second time it made a lovely smash in his engine!
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
garth
PostPosted: 19:55 - 06 Oct 2009    Post subject: Reply with quote
The two D.I.D chains I've had have been better than any others I've used prior. I'd say yes.
craigs23
Mr Muscle
PostPosted: 20:08 - 06 Oct 2009    Post subject: Reply with quote
Um...how do you rate a chain?
Whether it breaks or not?
How many times you need to adjust it?
garth
PostPosted: 20:18 - 06 Oct 2009    Post subject: Reply with quote
How much adjustment it needs, stretch etc. Basically how much abuse it takes.
Not really an issue now as I use a scottoiler.
eddclarke
PostPosted: 20:19 - 06 Oct 2009    Post subject: Reply with quote
Has anyone ever used a Regina chain?
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
The Tot
PostPosted: 20:58 - 06 Oct 2009    Post subject: Reply with quote
Funny how this thread comes up today!
Edd, I'll let you know about the Regina Chain when i've put a few thousand miles on it. My bike is due in for new C&S after it's slapping like a cock on a flappy labia!
I was trying to make a choice between Tsubaki Alpha X-rings, DID VZ Xrings and the Regina Z-Ring set. AFAM were WAAAY to expensive for my liking. Suffice to say, the place were willing to do me a set of brembo rear pads + Regina C&S + fitting for £200 (would do it myself but have neither the tools nor time).
Either way, all the brands have been used by major race teams so hopefully their experience will transfer onto the road. I'm expecting 20k miles on ANY X-ring chains.
Avoid IRIS. Despite constant lubrication and cleaning (every 2 weeks), they get tightspots notoriously easily. I've never seemed to get more than 8k miles out of a set of IRIS, both on the blade and on the 6R!
Never argue with autism
Charlie
PostPosted: 21:04 - 06 Oct 2009    Post subject: Reply with quote
My DID chain has only ever got adjusted when the back wheel needs to come for what ever reason. The chain has outlasted my front sprocket, I have just changed the front sprocket, I dunno what is going to happen with everything else.. (i.e. the chain and rear sprocket)(and the fact that you are meant to change everything together).
AngelGrinder
PostPosted: 21:10 - 06 Oct 2009    Post subject: Reply with quote
I've ordered, got an X-ring Tsubaki and a front renthal sprocket for £83 which I think is pretty resonable!
Just a quick question on fitting....
I know when you swap the chain, the easiest way is to link the old one to the new, then spin it round so it draws the new chain through.....
How do you do this if you are changing both sprockets?
I am also doing the chain in the pikeys way - angle grind the rivet, screwdriver to prise open. Then molegrips and a hammer to rivet the new chain on!
PostPosted: 22:10 - 06 Oct 2009    Post subject: Reply with quote
If you're changing both sprockets you'll have enough stripped off the bike to feed the new chain round by hand. This would also be a good opportunity to get a spray-bottle of degreaser and clean all the gunge from behind the sprocket cover.
tatters
Exxon Valdez
PostPosted: 22:20 - 06 Oct 2009    Post subject: Reply with quote
All the top x ring chains have been quite good on my prevoius bikes, l would never touch IRIS chains after a bran new IRIS O-ring chain snapping and punching a hole through the crank case of my NC24 after 80 miles.
PostPosted: 13:23 - 07 Oct 2009    Post subject: Reply with quote
DID chains are good and worth paying a bit extra for. But then are Tsubaki chains. How much extra probably depends on the particular chains.
yvaiwhy
PostPosted: 18:27 - 07 Oct 2009    Post subject: Reply with quote
have been using D.I.D chains on 2 of my bikes...one dual sport and a road bike...much better chain life....still haven't adjusted a bit after 8 mnths of use Very Happy
Don't break the speed limit, Just multiply it by 10 times and you will be fine Smile
PostPosted: 19:20 - 07 Oct 2009    Post subject: Reply with quote
Had a Regina chain on my Mille after the first one died.
Same as any other to be honest. Thumbs Up
eddclarke
PostPosted: 19:44 - 07 Oct 2009    Post subject: Reply with quote
Great, Im in the process of fitting a new C&S to my fz6. It was a bargain price £69.99 for steel sprockets and a Regina chain. As soon as I get a 32mm socket to remove the front sprocket.
The last post was made 16 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 103.31 Kb
