HELP
chris1984
PostPosted: 20:31 - 06 Oct 2009    Post subject: HELP Reply with quote
Have broke the thread on the sump on my zxr 400 does this mean a new sump of is there a way around this,thanks
PostPosted: 20:38 - 06 Oct 2009    Post subject: Re: HELP Reply with quote
You can repair it in a number of ways:
Use a timesert or helicoil to repair the original thread, and fit a new sump plug & washer.
Tap a new, larger thread, and fit a new, larger sump plug & washer.
Remove the sump, clean & degrease it thoroughly, then use JB Weld to fix the sump plug in permanently, after drilling & tapping it for a smaller bolt to use as a new sump plug.
Few other ways not worth mentioning/too bodgy.
Personally, I'd go for the 1st or 2nd remedy as the best repair & most cost effective.
chris1984
PostPosted: 20:46 - 06 Oct 2009    Post subject: Reply with quote
Thanks for the reply,how does helicoil work is it something i could do and would the sump have to come off for this job.
PostPosted: 22:57 - 06 Oct 2009    Post subject: Reply with quote
You should ideally remove the sump, since it's a simple job and you can then ensure no swarf or other debris gets in the oil. It's quite possible to do a repair with the sump in place however.
Helicoils work by fitting a spring-steel thread in place of the original thread using a special insertion tool. You could do it yourself, but the helicoil kit would probably cost the same as a used sump, or to pay a bike shop to do the helicoil.
My advice is remove the sump and ring-around to find an engineering shop or bike shop who will fix the thread. If you were local to me I'd do it for nowt.
chris1984
PostPosted: 04:50 - 07 Oct 2009    Post subject: Reply with quote
Thanks for the advice,i live in ireland so not sure where to get these helicoils so might just ring around for a secondhand sump.
The last post was made 16 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 43.9 Kb
