 veze Trackday Trickster
 lonner Spanner Monkey
 Posted: 10:14 - 11 Oct 2009 Post subject: |
hi
i had one of them in 1986 and it was fabulous then and there a very quick bike and it handled great too.
the one you have now is going to need all the usual stuff checking and or replacing
shock
head race
swing arm bearings linkages etc
fork service and a through engine service.
dont go sticking a huge rear tyre on it stick with the 150
the valves dont need checking till 28k so there pretty dam good and that engine is as smooth as any bike ive had
got any pics  |
 Posted: 16:39 - 11 Oct 2009 Post subject: |
I have one floating around.
They are good solid bikes. As mentioned above the valves very rarely need touching. 28k is the interval, but a good chance that they will mostly be fine at that time.
Only real weak point of the engine is the bearing behind the front sprocket. Generally fine but can fail if the chain is over tightened.
Build quality is not bad. Top speed is just under 150mph. No real step in the power delivery (just don't use a Micron exhaust on one, unless you like a big flat spot between 3k and 4k), just smooth power the whole way through. Seat is, err, something rejected by the Spanish Inquisition as being too cruel. Brakes are not that good (seize up easily). The electric reserve switch system is great. Fuel gauge is more accurate than those fitted to most bikes.
Note that there are lots of differences between the original 1FN models and the later ones. Different ignition system (coils, cdi units, etc, not interchangeable). Rear suspension linkage is very different.
 Posted: 22:05 - 12 Oct 2009 Post subject: |
im going to go and have a better look at her this week  ____________________ tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300 |
