Help I think I've done something stupid
PostPosted: 09:16 - 13 Oct 2009    Post subject: Help I think I've done something stupid Reply with quote
Hello,
I think I've done something silly. I was repairing the threads on the side of my RD350YPVS barrel where the powervalve pulley casing bolts on to the barrel. I think I drilled a little bit further than I should have and a drop of coolant appeared in the hole. I've repaired the thread successfully, and put the bolt back in place but will I need to do anything else to seal it up? I'm hopeful that it will be OK because its only like I've added another drain plug further up the barrel! Laughing
Any thoughts?
tatters
Exxon Valdez
PostPosted: 10:24 - 13 Oct 2009    Post subject: Reply with quote
You might need to use some loctite thread sealant on the bolt if it leaks, do not use anything like plumbers tape as it will not withstand the heat.
https://www.blue-diamond.co.uk/products/loctite/threadsealing2.html
PostPosted: 10:57 - 13 Oct 2009    Post subject: Reply with quote
I find that hard to believe.
Plumbers tape is made of PTFE. The same stuff they coat non-stick frying pans with. Its melting point is 327 degrees.
hmmmnz
PostPosted: 11:53 - 13 Oct 2009    Post subject: Reply with quote
haha burn!!! Very Happy Thumbs Up
the humans are dead
I kick arse for the lord
The last post was made 16 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 42.26 Kb
