| natefz6 |
 natefz6 Brolly Dolly
 Posted: 09:29 - 13 Oct 2009 Post subject: Flat battery every month :( |
So now that the weather is getting colder my bike starts to play up a bit more. It just does not like to start in the cold. It is a Gs500 and I seem to have to take the battery out to charge it every month.
Last year I brought a new battery its a YUASA and I was told that they were meant to be good. How long do they last? Could it be something else causing the battery to die? I have checked oil levels, always start out of gear and give it full choke. I only get around 3 chances to turn it over before the battery is dead, so if I am unlucky like this morning then it will not catch and I end up on the train .
Does this just sound normal? Do I whine too much?
Help!
Thanks ____________________ "no I didn't steal it that's just the way I ride" |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 10:36 - 13 Oct 2009 Post subject: |
Why didn't you bump start it?
Get a test meter and check it is being charged with the engine running. But if the bike isn't used much it will lose charge. Are you sure it is the right capacity battery for your bike?
Yuasa batteries are the Vauxhall Corsa of the bike world, everyone thinks they are good until they try something else. I would never go back to the lead acid batteries again. Gel is a bare minimum but prefer AGM because they don't lose charge and have very good cranking power. ____________________ Andy Sez....
F.Y.Y.F.F. |
 Posted: 11:08 - 13 Oct 2009 Post subject: |
A Yuasa battery should last way more than a year. However if you have let it go dead then (as with any lead / acid battery) you will have damaged it.
Seems odd that you need to charge it "every month". I would expect a knackered battery to need charging far more often than that, same if the charging system was faulty.
It does take a bit of time to replace the charge used when starting the bike, so possible you could be causing issues if you are doing lots of short journies, especially with lights on / heated grips / anything else that takes a load of power.
| iooi |
 iooi Super Spammer
 Posted: 11:25 - 13 Oct 2009 Post subject: |
I think a little more imformation about your bike usage will help.
Like....
How often do you ride it, how far is each trip, do you run with lights on all the time and which ones, do you have estra eletrical bits connected, such as heated grips. Does the bike have a alarm, where is it stored.
With the bike running meter the battery, what is it reading. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| smegballs |
 smegballs World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
| natefz6 |
| iooi |
 iooi Super Spammer
 Posted: 18:08 - 14 Oct 2009 Post subject: |
Should have 12V with engine off and around 14V with it running.
So you are doing around 20 miles a day then.
If your bike is stored in a safe place at each end i might be tempted to dump the alarm, as i bet thats the main reason for the flat battery. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
 Posted: 19:21 - 14 Oct 2009 Post subject: |
Bike becomes difficult and un-co-operative once a month?
It's obviously a female. Buy it some chocolates. ____________________ a.k.a 'Geri'
| hmmmnz |
The last post was made 16 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
