Steering Wheel Wobble :S
Martay
PostPosted: 17:26 - 24 Oct 2009    Post subject: Steering Wheel Wobble :S Reply with quote
Hi,
I know this is a bike forum, but was hoping someone could help. I have just test driven a Mk4 fiesta 1.3, and to be honest, it terrified me. Confused
The steering wheel shakes violently at anything over 5mph, and the steering is REALLY REALLY heavy. There is no play in the steering box, could someone suggest a cause of this? Possible tyres or wheels out of balance?
The car is great other than this, and cheap to Smile
Ta
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Phoenix
Twisted Firestarter
PostPosted: 17:31 - 24 Oct 2009    Post subject: Reply with quote
If it's when driving normally then could well be wheel balance out, if it's when braking then likely to be warped discs. If the car has power steering and it's heavy then it's likely the pump is failing or low on fluid or possibly a slipping/damaged belt, it doesn't sound like a well maintained car so i'd walk away.
I should probably point out it could well be more serious or complex issues which is why I say walk away, unless it's cheap enough and you have the knowledge and skills to fix it yourself, which I assume you don't, doesn't sound like a good first car.
Martay
PostPosted: 17:34 - 24 Oct 2009    Post subject: Reply with quote
Thanks Smile
Its NON-PAS, but i struggled to turn the wheel, when still or moving... Confused
It wobbled constantly while moving, braking turning or whatever. Tbh, now i think about it, i may well walk away. Thanks for the reply Smile
V2
PostPosted: 17:37 - 24 Oct 2009    Post subject: Reply with quote
Could be anything, as suggested from a wheel out of balance, a badly warped disk, accident damage that has not been repaired properly, I wouldnt walk away though, id run! Laughing
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 18:01 - 24 Oct 2009    Post subject: Reply with quote
Drew wrote:
I'd rule out wheel balance, as that only shows its ugly head at around 60mph, not before, and not after.
No thats like saying tank slappers only happen at 71.678mph.
I'd actually walk away from that. From what you describe it could be anything from a dinged wheel, to a wheel out of balance (that can show up about any speed) to a completely warped chassis.
PostPosted: 18:39 - 24 Oct 2009    Post subject: Reply with quote
Drew wrote:
I thought you would know these simple things with your oh so great knowledge of cars that you claim to have on these forums Wink
Well, I've had problems with wheel balancing that causes issues at 50mph, and I've had ones that cause problems at ~90mph. Go figure.
PostPosted: 18:47 - 24 Oct 2009    Post subject: Reply with quote
Drew wrote:
So not 'anything over 5mph' as the original post stated? Rolling Eyes
No, but not exactly at 60mph as YOUR post stated.
So we're both wrong! Razz Razz Razz Razz
binge
Emo Kiddy
PostPosted: 19:55 - 24 Oct 2009    Post subject: Reply with quote
Fords, Especially the Mk4 Fiesta and the Escorts, Are prone for Lower arm (Wish bone) bushings wearing.
At work, I do lower arms on Fiestas, More than any other cars, Put together!
Worn Lower arms will cause the steering to feel very heavy, And as you get to full lock on the steering, It will feel like its snatching out of your hands as you drive, Rather than straightening up by its self. If that makes sense?
It could also have a seriously out of shape tyre. Again, Worn lower arms would cause the tyres to wear prematurely, And in many cases, un-evenly.
Again, I'd walk away, Unless its going for very silly money. Sub £200 I'd say.
Ben
MaybeGuy
PostPosted: 20:18 - 24 Oct 2009    Post subject: Reply with quote
my vote is for drive shaft, wheel bearings or differential.
tried any other gears?
PostPosted: 21:19 - 24 Oct 2009    Post subject: Reply with quote
'Around' being the key word, in both of my posts above, so technically I am not wrong, and you are Razz Very Happy
How about the "And not before and not after bit Drew? Rolling Eyes
dgo1212
PostPosted: 23:15 - 24 Oct 2009    Post subject: Re: Steering Wheel Wobble :S Reply with quote
Out of shape tyre maybe?
Would rule out balancing and bottom arms if it's at low speeds
Re-call one of lads I work with fixing a heavy steering problem on a fiesta,am sure it was the coupling between the column and rack he replaced,apparantly they're a common fault but I've never done one myself
Edit-binge beat me to the tyre
Martay
PostPosted: 08:46 - 25 Oct 2009    Post subject: Reply with quote
Thanks for the advice guys Smile
I have decided against this one, all the problems that have been suggested sound expensive to fix!! Shocked
The car is advertised as 'drives very well', all i can say is, im pleased i test drove it!
binge
Emo Kiddy
PostPosted: 08:50 - 25 Oct 2009    Post subject: Re: Steering Wheel Wobble :S Reply with quote
Forgot about the UJ or whatever its called on the steering rack. I've changed a few of those on the Fiesta's too. They have a habit of seizing up.
Ben
The last post was made 16 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 102.08 Kb
