Thinking of getting a new bike... this one caught my eye
guyal
PostPosted: 09:51 - 25 Oct 2009    Post subject: Thinking of getting a new bike... this one caught my eye Reply with quote
https://www.autotrader.co.uk/classified/advert/200943344503058/sort/priceasc/usedbikes/engine-size-bikes/325cc_to_525cc/postcode/ne55np/quicksearch/true/page/1?previous=%2Fsearch%2Fresults%2Fusedbikes%2Fpostcode%2Fne55np%2Fengine-size-bikes%2F325cc_to_525cc%2Fquicksearch%2Ftrue%2Fsort%2Fpriceasc%2Fpage%2F1&anchor=advert200943344503058&logcode=p#
I was thinking of moving onto something a little bigger than my little 125. What do you guys think of this bike? Can you see anything wrong with it? Do you like it? Would you buy it? I'm pretty much in the dark here, and don't want to buy a pig in a poke, so any advice (no matter how condescending and patronizing) would be appreciated.
Also, I'm only 17 (doing my test this Wednesday) so I'd need to get the bike restricted, if I'm going to do it legally. It is possible/ worth it to not bother? Or i I do end up restricting it, any idea how I could get it done/ how much it would cost?
Thanks Wink
https://pictures2.autotrader.co.uk/imgser-uk/servlet/media?id=1007453953
guyal
Nb
PostPosted: 10:02 - 25 Oct 2009    Post subject: Reply with quote
Its fairly old but looks to be very clean, looking on google i can see a vt500 33bhp kit listed here https://www.bat-motorcycles.co.uk/33bhp.asp but not sure how much it would cost to fit. Also he looks to have gone a bit mad with the tyre shine on the tyres! Shocked
yen_powell
PostPosted: 10:10 - 25 Oct 2009    Post subject: Reply with quote
That bike (and the CBX550) was famous for wearing out brake pads and discs on the front wheel because, being enclosed, no one ever checked them till it was too late.
XT1200Z and a DR350 in bits
Kaz96
PostPosted: 11:12 - 25 Oct 2009    Post subject: Reply with quote
My other half had one of these years ago and I currently ride the cruiser version (also on a B), that was left unloved and exposed to all the elements for 9 years and apart from cosmetic work, the engine just needed the valves tweaked and the obvious bits replaced, but it runs perfectly... the engine and frame are pretty much the same on both bikes!
The only niggles he had with the VT500 EF was the brake hose was a rubber one, this will need to be replaced with a braided hose if not already done. The other thing was the rear indicators, the originals tend to stick out and are easy to knock off... so would be better replaced with smaller/mini indicators. Aside from that he loved the bike and only sold it because he was offered more than he actually paid for it!!
As for the issue of the brakes going unchecked until it was too late, you need to make sure you do check them and should do so no matter what you ride!
Good luck with your test! Smile
The Original Muzza
PostPosted: 11:14 - 25 Oct 2009    Post subject: Re: Thinking of getting a new bike... this one caught my eye Reply with quote
guyal wrote:
Can you see anything wrong with it? condescending and patronizing
Yeah, the clutch cable is worn and it has been run without oil. Wink
Kaz96
PostPosted: 11:21 - 25 Oct 2009    Post subject: Re: Thinking of getting a new bike... this one caught my eye Reply with quote
LOL Muzza Mr. Green
PostPosted: 11:23 - 25 Oct 2009    Post subject: Reply with quote
If the engine sounds as good as the rest of the bike looks, I'd have it in a heartbeat.
https://www.usedbikeguide.com/bible/display.asp?id=150
guyal
PostPosted: 12:01 - 25 Oct 2009    Post subject: Reply with quote
It does look very clean for such an old bike, doesn't it? I thought it looked brand new. Is the shininess of the tyres in any way a bad thing?
guyal
guyal
PostPosted: 12:02 - 25 Oct 2009    Post subject: Reply with quote
Does this mean that they wear out quicker than on other bikes, or they just get neglected? Is this a reason to avoid this particular bike?
guyal
guyal
PostPosted: 12:03 - 25 Oct 2009    Post subject: Re: Thinking of getting a new bike... this one caught my eye Reply with quote
[Citation needed]
guyal
guyal
PostPosted: 12:04 - 25 Oct 2009    Post subject: Reply with quote
Thankyou! Smile
guyal
guyal
PostPosted: 12:05 - 25 Oct 2009    Post subject: Reply with quote
I am unbelievably tempted. You have no idea.
guyal
guyal
PostPosted: 12:07 - 25 Oct 2009    Post subject: Reply with quote
One more thing I've just thought of- I'm not overly keen on the fairing and the square headlight, although it is growing on me and it's not that much of an issue. But if I were to replace it, how easy do you think it would be to find an alternative headlight? I emailed the seller who said it's easy to remove both, but I would need to find another light that would fit inside the brackets.
guyal
PostPosted: 12:12 - 25 Oct 2009    Post subject: Reply with quote
Looks clean for a VT. Biggest problem with them is that most land up being destroyed by being used as courier bikes.
Suspect if you take the fairing off you will discover a hideous mess of wiring, and any aftermarket fairing is likely to look tacky and nasty compared to the original
guyal
PostPosted: 12:16 - 25 Oct 2009    Post subject: Reply with quote
Do you think it's possible that it has been used as a courier bike?
Also about the fairing, if anything I wouldn't replace; I'm just leave it off, and replace the headlight, as I prefer the more naked look. Just an idea though.
And thankyou Smile
guyal
Kaz96
PostPosted: 12:17 - 25 Oct 2009    Post subject: Reply with quote
Shiny tyres means its been polished more than ridden! Laughing
The brakes were just neglected!
Headlight can be replaced fairly easily, just make sure you replace it with a halogen one!
guyal
PostPosted: 12:21 - 25 Oct 2009    Post subject: Reply with quote
Why Halogen?
guyal
PostPosted: 12:24 - 25 Oct 2009    Post subject: Reply with quote
Unlikely. Many courier bikes are ridden into the ground, and it would take far too much effort to get them that clean again.
Personally I think it would land up looking pretty dire. Scrappy wiring hanging out and the back of the clocks open to the elements.
Kaz96
PostPosted: 12:27 - 25 Oct 2009    Post subject: Reply with quote
guyal wrote:
Why Halogen?
I made the mistake of replacing the one on my VT500c with a non halogen one and it's not a lot of fun being blind on a dark country road! Laughing
Polo
PostPosted: 12:48 - 25 Oct 2009    Post subject: Reply with quote
Psssssst, the link at the top has your full post code/ Wink
My mum smells your fingers
guyal
PostPosted: 12:49 - 25 Oct 2009    Post subject: Reply with quote
That bad huh? Well thanks for the advice Wink
guyal
Steve-D
PostPosted: 19:10 - 25 Oct 2009    Post subject: Reply with quote
My sisters boyfriend has the C version on an A plate.
Engine is pokey enough, his brakes aren't enclosed, but they are shocking. Lever goes to the bar pretty much.
Don't know if its just him refusing to listen to me when I say they don't work all you get is a load of fork dive.
Luckily has lots of engine braking so sort of evens itself out.
Good price as well, he paid 825 for his, and its a shed and doesn't know how many miles its done.
www.southwestbikers.com
bazza
PostPosted: 21:38 - 25 Oct 2009    Post subject: Reply with quote
The residents of Brendale Avenue care not for such trivial matters.
Dragonfly
PostPosted: 23:46 - 25 Oct 2009    Post subject: Reply with quote
Looks clean and well looked after, nice shiny chrome! best not leave it in my hands chrome rusts around me. Laughing
nice bike and I normally dont say that about older bikes but that one is in good condition.
All the breast.
Muzza on Binge:
Kaz96
PostPosted: 11:07 - 26 Oct 2009    Post subject: Reply with quote
The brakes on my C work fine, the only time the lever has gone to the bar is when they have been stripped and need bleeding.
The last post was made 16 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 131.96 Kb
