Engine cleaner/restorer.
TimNorwich
PostPosted: 19:36 - 26 Oct 2009    Post subject: Engine cleaner/restorer. Reply with quote
Hello again! Laughing
The previous owner of my Cg125 had the accident and then stored it away without cleaning the engine. It has now corroded and looks really quite tatty, is there anything I can put on to restore it?
There are also a few really rusty bolts, where would be the best place to find some replacements?
Thanks
Tim.
stirlinggaz
PostPosted: 21:44 - 26 Oct 2009    Post subject: Reply with quote
Hi,
not sure how far you want to take it, but a wire brush & black ht paint is a good start.
or if your stripping it down, bead blasting & polishing?re-plating?
various options.depends how far you want to take it & how much you want to spent.
as for nuts & bolts, dont bother with oem stuff, just take the old ones into your local hardware shop & buy like for like.
or you could do what i did & spend about 50 quid! but for that i got nuts & bolts of almost every size you need, with washers,spring washers,nuts,nyloc nuts etc.
hardly needed to buy a nut or bolt yet. (any that are too long , i just cut to size with boltcutters or dremel)
cheers,
GAZ
Glory Hunter
PostPosted: 22:13 - 26 Oct 2009    Post subject: Reply with quote
Apologies for hijacking, but I have a similar problem.
I was thinking about rubbing down the engine casings with various grades of wet and dry paper then coating the engine with ACF 50 until the spring when I'll re-paint it.
Anyone got any opinions on this?
Also, the down pipes on my exhaust are slightly rusted (only surface, no deep corrosion), is it possible to polish these and again treat with ACF50 - if I use a polish, is it likely to cause a problem when the pipe heats up?
2003 Suzuki VanVan - Sold
2000 Honda CB500 - written off by a spoilt brat with no manners Sad
2005 Yamaha XT660 - I'm in lurve.... Smile
PostPosted: 22:24 - 26 Oct 2009    Post subject: Reply with quote
Wire wool or sand paper the exhaust and then polishing should make the pipe look new again. Polishing it won't affect the downpipe. If there is polish residue left on the exhaust it will burn off.
Glory Hunter
PostPosted: 22:37 - 26 Oct 2009    Post subject: Reply with quote
Thanks for the advice, I guess I know what I'll be up to next time we get a dry weekend...
Nipedley
PostPosted: 23:33 - 26 Oct 2009    Post subject: Reply with quote
My CG has been sat out in the rain for a few years - actively used and maintained throughout though, but the engine's aesthetics degraded... The non-painted metal part (cylinder/head) got really bad looking, with salty-like deposits all over it.
A few weeks ago I took a wire brush to it and all of the "salt" (I say that as I don't really know what it is, but it looks like salt) literally brushed off like powder. I had to rewash the bike as it had all settled on the front wheel!
It's not easy to shift but it goes with wire wool/wire brush. Looks much better now.
PostPosted: 00:50 - 27 Oct 2009    Post subject: Reply with quote
It's aluminium oxide.
Nipedley
PostPosted: 16:34 - 27 Oct 2009    Post subject: Reply with quote
Way to make me feel stupid :lol
But yes, the aluminium oxide comes off easily enough with a wire brush. Very Happy
PostPosted: 20:27 - 27 Oct 2009    Post subject: Reply with quote
You could have it wet-blasted (like shot blasting but using water instead of air as a carrier). There's always the risk of getting the media in the engine though.
ZRX61
Victor Meldrew
PostPosted: 01:33 - 28 Oct 2009    Post subject: Reply with quote
Hot water & soapy brillos also work wonders.
The last post was made 16 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 65.45 Kb
