| Mark65 |
 Mark65 World Chat Champion
 Posted: 16:17 - 29 Oct 2009 Post subject: YBR125 Fork Cap Socket Size |
As the title, does any one know the correct size i have one in 11mm but its abit too small. I plan to change my fork oil and spring preload this weekend so i need to buy the correct size, its a female bolt, also the italian sevice manual i have says 0.154 litres of oil or 0,136 imp qt which doesnt sound like a lot really?, then it shows a diagram of fork oil height suggesting 166mm from top of tube?. Can any one confirm this pls?. And would a litre bottle of fork oil be enough for both forks?.
Thanks for any help.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| ms51ves3 |
 ms51ves3 Super Spammer
| neil. |
 neil. World Chat Champion
| neil. |
| Mark65 |
| Mark65 |
| Mark65 |
 Posted: 17:26 - 30 Oct 2009 Post subject: Fork Tweak Update |
Hi all
Update: well you were right , it was a peice of piss to take the forks off and drain, springs are 135mm so are spot on, now on the oil amount should i go off the amount 156ml or height 166mm from top, now if i go with height is that with the forks extended full or not ? and with the spring in or not?.
Now to tweak, i will use 15w fork oil, so as i want a bit mor preload and stiffer dampning should i put 10mm worth of washers in to start with and extra 10-20mm of fluid height?, Any recommendations pls.
| ms51ves3 |
| TUG |
 TUG World Chat Champion
| Mark65 |
 Posted: 20:48 - 30 Oct 2009 Post subject: |
All off and stripped down in the garage lonewolf, will have to nip in tomm for 15w oil as i cant seem to find any. halfords only have 10w. I tried the car acc shop in hindley but his valvoline bike oil was dated 2005 , oh and i need brake pads they are almost at there limit, so do i go yamaha or ebc?
| TUG |
| Acemastr |
 Acemastr World Chat Champion
| TUG |
| neil. |
 Posted: 13:29 - 31 Oct 2009 Post subject: |
I would also add when you put the new oil in, pump the forks quite a few times until you don't hear 'bubbling' any more (the sound changes quite noticeably), so the oil gets into the nooks and crannies BEFORE you measure.
As for brake pads, there is a lot of differing opinions on sintered vs non-sintered (organic/kevlar). I chose organic in the end to reduce wear on the disc and for a low power bike I didn't feel I needed extra braking power. Also, it is my understanding that sintered pads work better in the warm, but I'll be running the bike in winter. However that's all I know so someone else here will probably chime in with more info. My 2005 YBR (3D91) uses EBC FA101 size pads. The 2007+ (3D92) model uses a completely different pad - EBC FA464.
 ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| Acemastr |
| Mark65 |
 Posted: 19:03 - 31 Oct 2009 Post subject: |
Ace there are two different pads for the,, the later ones are larger 2007 and on i think, the bad news is my forks are bent slightly, i havnt crashed or owt so im thinking the chap before me may have bent them or they may be faulty, when they are installed you cant see the bend as it is only 2-3mm, i only noticed when i extended them, so im waiting to see what yamaha say.
So its the car for a few days Now just in case yamaha have me grab my ankles, where can i get ybr fork tubes cheap (just the inners).
| ms51ves3 |
 Posted: 22:59 - 31 Oct 2009 Post subject: |
If they are only slightly bent you can have a look at getting them straightened. It may be cheaper than buying new ones.
| Mark65 |
| ms51ves3 |
| TUG |
| Mark65 |
 Posted: 10:30 - 02 Nov 2009 Post subject: |
| ms51ves3 wrote: | | Mark1965 wrote: | Yes i pass by within a mile of there every day to work, so i have e-mailed him, one is about 1.5mm and the other 3mm out, so if as long as its only 10-15 per fork i may do yet.
Thnx
Mark |
Be sure to post up how much it costs as I'd be interested  |
£20 per leg,if stripped, £110 if they do all the work.
Now considering i keep the bike pristine as possible and have never come off or crashed it the damage must have been done by the previous owner, which i will try to contact, then Wigan yamaha sold me the bike with the slight damage on it, being fair though you cant see the bend when the forks are installed. They seem to think its nothing to do with them at this point i think as they sold me the bike it should have been right , so they are contacting yamaha today to see if they will do anything, so will they do the decent thing or not we will see. New stanchions are £60 each.
| ms51ves3 |
| Mark65 |
| Mark65 |
 Posted: 13:20 - 02 Nov 2009 Post subject: |
Well phoned Wigan Yamaha up and the service chap has no idea what i was talking about, so after going through it and putting his views, which were basically if youve ridden with the forks bent for this amount of time whats the problem , But my point is they are faulty and unless you take them off you would not have seen it. Now i did say i didnt think anyone was to blame here but there must be a solution to the problem that will keep both partys happy.
I have said if the fork tubes are £60 retail i would be happy if they were supplied to me at £30 each, obviously they are not loosing £30 as they would not be paying £60 for them from Yamaha, then i would install them myself, i think this is a fair solution really, but if they palm me off with crap as i have a feeling they will then when its time to buy the big bike my money will go elswhere, so for the sake of £60 they could loose a thousand or so.
| ms51ves3 |
The last post was made 17 years ago. Instead of replying here, would creating a new thread be more useful? |
