info
PostPosted: 21:01 - 31 Oct 2009    Post subject: info Reply with quote
Hi every body i have just brought this motorhispania rx 50 2002 modell is a great bike. But the front lights bearly work not very bright at all i have changed the buld and still dosnt work so was wondering if anyone esle has had these problems and if they could help me out and also the when i press the back brake the brake light dosnt work thank you for reading and if could help that would be great thanks.
joe.l
BenR
PostPosted: 21:05 - 31 Oct 2009    Post subject: Reply with quote
Does the headlamp brighten/dim when revving the engine? Sounds like a charging problem may need a new stator or regulator/rectifier. the rear brake light switch may need adjusting, check to see if it's adjustable if not replace it should cost too much.
125 125 250
PostPosted: 21:11 - 31 Oct 2009    Post subject: info Reply with quote
hi yes it does light up a bit when rev but not much do you know how much the stator and other things you said would cost oh and thanks for the back brake info thanks for replying.
joe.l
Acemastr
PostPosted: 21:16 - 31 Oct 2009    Post subject: Reply with quote
my YBR brightens up when revved, thinking it's just the fact that the reg on a 125 really isn't big enough. I tried a 55w bulb as opposed to 35w standard, it's brighter but charging is an issue as it draws a fair bit of power.
2016 Toyota Tacoma Limited
Mystery
PostPosted: 21:45 - 31 Oct 2009    Post subject: Reply with quote
its just standard lights in general on some bikes my nsr 125 is the same its so crap on a night
The last post was made 16 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 42.44 Kb
